20 Most Recent
Splendide 2000S Front Load Washer / Dryer Questions & Answers
Splendide 2000 wd802m
Omg...thats your steamer thingy...nice. that's new tech. If it's a factory install and you have potable water in your holding tank and / or are hooked to water pipe you are good to go with the latest tech in fabric care. Lucky gal
We purchased a used motorhome
It should lock on all functions. It may be a bad lock or the connection to the lock. I would call the support for that unit, Westland Sales 503-655-2563.
Splendide 2000 model# wd802 drains byt will not spin nor turn
I have a splendide 2000 / WD802 pre m with round power buttons. It came with a used RV I bought. Everything would work on it except the drum wouldn't spin at all. After some research and messing around with it I was able to fix it! You remove the back panel and in the bottom left corner there is a white control module chip board mounted in by two screws. Remove the two screws from the back for access to fix it. Now the top plug on pin 1 and 2 shoud have 2 white wires connected to pin 1 and one baby blue wire connected to pin 2. I jumped these 2 pins together with a small length of wire and now our machine spins and works great! Be sure to used at least 6 inches of wire at least as thick as the rest of the wires and make sure that it is well connected. I recommend you take the crimps off the blue and white wires and re crimp them with the jumper wire crimped as well. If you don't have a good connection with a long enough wire it will get hot and possibly catch fire so it is very important to do this correctly. I hope this helps someone!!
Cycle selector knob clicks forward
www.
splendide.com/service/TRAINMANM_Complete.pdf
WD802M (Splendide 2000). WDC1025M ... 6SOHQGLGH¥. Front Loading AutomaticWasher Dryer ... Description of Preset Wash Cycles / How to Set A Wash Cycle ONL: 21. Description of .... may appear to work well after repair is finished, but failure may occur at a ..... rear of the main top, then slide forward. Removing the ..
