20 Most Recent
Route 66 MINI Handheld GPS Receiver Questions & Answers
Hard reset on Route66 mini
Try updating your Route66 with the latest edition of the PND software from the R66 support website -http://www.66.com/support/index.php?cid=UK&opt=updates - This will reset the sat nav to how it was when it left the factory but you will loose your favourites and history in the process. See the website for more details.
Do I need to wipe
Yes if you are getting an error that is the best way. You may want to consider purchasing a larger memory card and copying over the original files onto this new card. Hope that helps you.
Createfile failed on INI file
Hi. I had the same problem, and i fixed it by creating a APShell.ini file wich was missing in MyFlashDisk\Shell directory.
In APShell file :
Version=1.0.2.43
Language=23
[Navigation]
Path1=\SDMMC\ROUTE66\R66n8.exe
Path2=\SDMMC\N8\Navigate8UI.exe
Path3=\SDMMC\ROUTE66\R66Navigate8.exe
Caption1=Navigate
Caption2=N8
Caption3=Navigate
ClassName1=
ClassName2=Explore
ClassName3=
Reset=
reset device and it should work.
Route66 device F S070001795
the problem is that the drivers have some way uninstalled from the system and it is nedded to share the data between the system and the GPS system.try to reinstall the drivers and try.thank you
