20 Most Recent Navman N40i Handheld GPS Receiver Questions & Answers
I want to update my model how do I do it and how
Depends on what you mean by update. If you want to exchange your unit for a newer model, that is between you and the dearler/seller.
If you mean that you want to update the software in your unit to more updated maps, then do this:
Go to this site, and select your model, then choose update maps. You will likely have to download the maps file to your computer, then transfer then to your device. Instructions should be on the Navman website.
http://www.navman.com
good luck and don't forget to vote!!!
10/11/2010 4:54:27 PM • Navman N40i... • Answered on Oct 11, 2010
Hi. Where do I find my answer; can I update my Navman N60i maps
Go to the Navman web site and you will find your answer.
11/3/2023 6:27:48 PM • Navman GPS • Answered on Nov 03, 2023
How do I set up a Navman EZY 15 for UK use?
Not for that model. You can for others, you buy the UK map. I recommend the Garmin Drive 50 for the UK. I bought one for a friend in the UK and bought one for me here in Canada. https://www.navman.com.au/ezy15#Features https://www.navman.com.au/international-maps https://www.google.com/search?q=Australian+Navman+EZY15+UK+map ..
9/10/2023 6:04:54 PM • Navman GPS • Answered on Sep 10, 2023
How can I reset a Navman Micam GPS unit that says No Map Data Found after doing an update?
hello peter To restore the device to factory default settings, go to Settings > Device > Restore factory defaults. Please note that you will lose all stored information on the unit including addresses (ex. MY Places, Recent Locations). you can aslo contact the customer care
8/20/2023 2:06:41 PM • Navman GPS • Answered on Aug 20, 2023
My Navman Tracker 5500 is not locking on to satellites. What can be done to sort it out please?
This is an Australian unit. We are in North America. This link might work better for you. https://www.google.com/search?q=navman+Tracker+5500+not+locking+on+to+satellites ..
6/18/2023 8:25:57 AM • Navman GPS • Answered on Jun 18, 2023
I have a navman model no:no538-6000. it has frozen on the main screen
If your Navman GPS device has frozen on the main screen, you may be able to resolve the issue by resetting the device. Here are a few steps you can try to reset your Navman GPS device:
  1. Press and hold the power button on the device for about 10 seconds until it turns off.
  2. Disconnect the device from the power source and remove any batteries or memory cards.
  3. Wait for a few minutes, then reinsert the batteries or memory cards and reconnect the device to the power source.
  4. Press the power button to turn the device back on.
If the device does not turn on or the issue persists after resetting the device, it is possible that there may be a more serious problem with the device. In this case, you may want to consider seeking assistance from Navman customer support or a professional repair service. It is also a good idea to regularly update the software and maps on your Navman GPS device to ensure that it is functioning properly and has the most up-to-date information available. You can usually find software updates and map updates on the Navman website or through the manufacturer's support resources.
12/27/2022 6:07:57 AM • Navman GPS • Answered on Dec 27, 2022
Navman EZY 100T lost its voice while operating. Can this be fixed please?
This looks like an older unit and IIRC it is Australian, was discontinued and bought up by another company. Try a full Hardware Reset. Tiny hole, back, right side https://manualmachine.com/navman/ezy100t/1216368-user-manual/#19 https://www.google.com/search?q=Navman+ezy+100t+lost+its+voice ..
11/25/2022 5:21:42 AM • Navman GPS • Answered on Nov 25, 2022
How to update navman move 65
it's very easy and simple to fix. ready this article www.mydashupdates.com
12/14/2021 8:35:12 PM • Navman GPS • Answered on Dec 14, 2021
Can I download maps for South Africa onto the Navman Ezy 40 Series?
Hey i have same issue with my GPS i thought that time it was dead, but by software update you can give it a try. or i,ll also get helps by http://thelocationtracker.com/ Try. they will also updates maps of your choices.
10/18/2021 6:38:01 PM • Navman GPS • Answered on Oct 18, 2021
2answers
How to transfer contacts from iphone to bluetooth
You can transfer contacts to iPhone with Bluetooth. However, you can make it with Airdrop between Apple devices. Just follow below steps to do that. 1. On your iPhone, you need to swipe upwards to navigate to the "Control Centre" and turn on the feature of "AirDrop". Connect your iPhone to good Wi-Fi network for preparation. After that, you need to choose "Contacts Only" or "Everyone" as you like on iPhone. 2. On your Mac computer, you need to go to the interface of "Finder" and select "AirDrop" from the left-side column to enable the Wi-Fi function. You need to make sure both your iPhone and Mac computer are connected to the same Wi-Fi network. 3. In the "Finder" interface, you need to move to the option of "Allow me to be discovered by" and choose "Everyone", "Contacts Only", or "No One" in the light of your demands. I recommend you use "Everyone". 4. On your Mac computer, you need to kick off the "Contacts" app and then locate the certain contact you want to transfer to your iPhone. 5. Find the "Share" button at the lower right corner of the window to click on and then choose "AirDrop" as the sharing method. 6. Select your iPhone device in the AirDrop available lists, and then start transferring contacts from Mac to iPhone with one click. Thus, you can go to your iPhone to click on "Accept" to receive the AirDropped contacts from Mac. For more details, check: How to Transfer Contacts from Computer to iPhone
9/27/2021 6:00:14 AM • Navman GPS • Answered on Sep 27, 2021
How do i update my navman C60
you need a new one. C40 and C60 no longer supported. Buy Garmin instead. We appreciate your interest in updating your Navman device. However, the C40 is one of our old models. We no longer have updates available for it. This is due to the technological advances in mapping data over the past few years. The size of the mapping data is too great to be handled by the older hardware and we are unable to release map upgrades for these devices. We sincerely apologize for the inconvenience. The best option that we can offer is our trade-in program. You can take a chance to purchase a brand new device at a discounted price with full warranty. These new models will have the latest software and maps. And, most of the new models come with free map updates for Australia and New Zealand. You may click on the appropriate link below for more details: Australia https://www.navman.com.au/products/trade-in New Zealand https://www.navman.co.nz/products/trade-in Thanks, Navman Support Team Page 98 of the C40 / C60 Manual https://www.manualslib.com/manual/572075/Navman-C40-Series.html#product-C60-Series ..
7/17/2021 3:28:08 PM • Navman GPS • Answered on Jul 17, 2021
I cannot update my Navman C40
No updates. It is an old model. Buy a Garmin! Or they will give you a few bucks off for a trade in We appreciate your interest in updating your Navman device. However, the C40 is one of our old models. We no longer have updates available for it. This is due to the technological advances in mapping data over the past few years. The size of the mapping data is too great to be handled by the older hardware and we are unable to release map upgrades for these devices. We sincerely apologize for the inconvenience. The best option that we can offer is our trade-in program. You can take a chance to purchase a brand new device at a discounted price with full warranty. These new models will have the latest software and maps. And, most of the new models come with free map updates for Australia and New Zealand. You may click on the appropriate link below for more details: Australia https://www.navman.com.au/products/trade-in New Zealand https://www.navman.co.nz/products/trade-in
Navman C-Series C40 / 60 Questions ' ProductReview.com.au
www.productreview.com.au > listings > q-and-a
We appreciate your interest in updating your Navman device. However, the C40 is one of our old models. We no longer have updates available for it. This is due ...
12/31/2020 2:03:00 AM • Navman GPS • Answered on Dec 31, 2020
How do I upgrade my maps with my Navman MY50T
Navman Map Installation Instructions with unlock key youtube video to explain process. Semper Fi, Z
8/28/2019 5:57:11 AM • Navman GPS • Answered on Aug 28, 2019
How do I change date & time on a M105 Navman GPS
Manual mentions time zone change automatic or manually, but doesn't appear to have a date and time setting alone. http://service.navman.com/M0100/F0110_FileReader.aspx?fileid=113359&Region=Australia%20NAVMAN&Language=English%20NAVMAN
6/15/2019 12:42:02 PM • Navman GPS • Answered on Jun 15, 2019
Free maps to download direct to my navman E13 device
IWANT TO DOWNLOD THE CURRENT MAPS FOF NAVMAN e13
4/13/2019 9:52:26 PM • Navman GPS • Answered on Apr 13, 2019
How I can download Lebanon map on navman gps
Go to the Navman product support website and purchase the map set
4/10/2019 9:43:56 PM • Navman GPS • Answered on Apr 10, 2019
Cannot charge the new Navman MY690LMT
Can you charge it from the cigarette lighter cord? I'm thinking some GPS will neither charge nor run from a USB power source. Garmin, I believe, uses USB only for updates, not as a power supply.
3/31/2019 3:17:31 PM • Navman GPS • Answered on Mar 31, 2019
Navman N40i Handheld GPS Receiver Logo
8 questions posted
Top Navman GPS Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Mike Cairns
Mike Cairns
Are you a Navman GPS Expert? Answer questions, earn points and help others
View Most Popular
Navman GPS
  • Navman GPS
Most Popular Question
want update model
  • GPS
