20 Most Recent
Tomtom One V2 Car GPS Receiver Questions & Answers
When switched on green light next to switch flickers but that is all
It sounds like the TomTom isn't able to boot up. This may be due to a software or data issue.
Have you tried to (use HOME on your computer to) connect to the TomTom server ? to update the software/data, and/or tried to restore the software / data with the (previously) backed-up copy (that you had previously saved on your computer) ?
How can I set time?
You can set (or reset) your Time (& display format) using the "Menu".
From your Driving screen (showing map of current location), tap on the (middle of the) screen, to show the Main Menu (on the next screen),
Look for, and tap on "Change preferences".
On the next screen, look for and tap "Set Unit". On the next screen, select (tap on TIME), and you can set (reset) the (display) format and time.
How can I set time and volume?
These 2 things can be done using the "Menu". (You can also adjust the Volume from the Driving Screen - tap bottom left area and slide the volume bar to adjust the volume).
1. To set Time:
2. To set Volume:
On the next screen, look for and tap "Volume preferences". You can then tap on the bar (position) and test/hear the level of the sound. And/or you can select "Link Volume to car Speed" ... and tap Done.
How do I update maps on tom tom one from computer to GPS ?
Usually, you connect your TomTom to your computer, and use the TomTom software (e.g. HOME) to update (e.g. buy, download and install) your map(s).
If your question is about how to copy a (new / another) map on your computer to your TomTom device (i.e. without using the TomTom HOME software), you can simply copy the "map" folder (of the map on your computer) to your TomTom Device (that you've connected to your computer).
You may have other questions like, is there enough memory on your TomTom device for the map ?; is the (new/other) map version compatible for the TomTom (model/version) device that you have ?; is the map "activated" to run on your TomTom device? etc.
Signal not working in mercedes, works in ford pickup
Yes, If your device cannot acquire a signal when mounted on the windscreen, this may be because your car has Heat Reflective Shielding on the glass. This can block GPS signals from reaching your device, to solve this you may need to purchase an additional aerial.
AFTER LINK TO TOMTOM WEB SITE THE DEVICE NO LONGER WORKS? ONLY SHOWS LINK WINDOW.
Look up Tom Tom directly on the Internet and download the latest Tom Tom "Home" program. Make sure the Tom Tom you are using is the one that was originally set up to your account. If you have bought a new Tom Tom, it wont work until you have registered the new device. I had the same problem. I replaced an old Tom Tom with a new one and my old account wouldn't work as it kept saying the devices were not the same and that my email details were already in use for another unit.. I had to email Tom Tom to correct the account details.
