20 Most Recent
HP iPAQ RX5915 Travel Companion GPS Receiver Questions & Answers
My gps stop working on
If your gps does not come on anymore, there seem to be a problem somewhere, which most likely is from either the battery, the charger or both. Try another battery in the gps to see if it will work, if it works, then it means you will need to get another battery for your gps.
Test the charger also on another gps to see if it will charge, if it charges it, then it is okay, but if it does not, then it is bad and need to be replaced. Either way, you have detected the cause and solved the problem.
But if your gps normally comes on and does not read map or signal, then you need to reset your gps. Or update to the latest version of software for your GPS.
Hope this information helped.
I am considering buying a
i would not buy another ipaq if someone gave me the money..the last two i bought (600.00 ea) both took a **** right after the warranty ran out....
HP did nothing to help even though it was within a day (how lucky i am) of expiring.
Freezing at the "HP iPAQ
I had same problem. Finally got mine sorted!!
Try a full reset. Hold the quick launch button and the rotate screen button simultaneously (top and bottom of 4 buttons on left of device) and then use stylis to press in the reset button (on top edge just left of SD card slot). Keep depressed until it resets then release the 2 buttons and then release reset button.
It will appear to do the same but it tells you at the bottom it is doing a reboot or something. After 30 secs or so it then goes past and gets to the screen align screen.
You might loss settings but it worked for me
My ipaq does not load fully
You might loss settings but it worked for me.
What do you think about new york city exterminators?
There are various websites on internet that are presenting new york city exterminators. These are specially-made for those people that are trying to find quality service. To find out more please visit with this site :http://www.mypestsolutions.com/
4/18/2024 4:19:04 AM •
GPS
Answered
on Apr 18, 2024
My Conlog Prepaid electricity Meter is showing a spanner and not bring in light. What should I do?
Question edited for clarity. It is 'Conlog', not 'cinlog'.
It means there is a technical fault. Phone the company that supplies your electricity. It is their meter and distribution network.
What are the causes of a spanner appearing on ...
Quora
https://www.quora.com > What-are-the-causes-of-a-spa...
Jul 15, 2023 - A spanner icon anywhere indicates a need for maintenance. If the light is orange, get the service as soon as. If the light is red, call a ...
3 answers ยท 6 votes: Spaaner that appears on any equipment is the symbol of due for maintenance. Follow the OEM ...
Help! My Prepaid Meter Is Showing A Spanner Icon.
Nairaland
https://www.nairaland.com > prepaid-meter-showing-spa...
Mar 7, 2022 - I noticed my neighbours still had. On getting outside to check the conlog ip54 prepaid meter, I saw a spanner icon and a negative reading of the energy balance.
Please Help With My Conlog Prepaid Meter - Technology Market
Aug 6, 2020
I Need A Technician To Fix This... - Nairaland / General - Nigeria
Jul 22, 2019
Please Help With Conlog Prepaid Meter - Technology Market
Oct 9, 2022
Help My Prepaid Meter Stopped Displaying! - Nairaland Forum
Aug 3, 2023
More results from www.nairaland.com
3/8/2024 9:09:19 PM •
GPS
Answered
on Mar 08, 2024
