20 Most Recent Navigon 2000S GPS Receiver Questions & Answers
Are you sure that it is not asking to be updated?
Navigon 2000S... | Answered on Nov 27, 2017
When you go to new destinations it say,s enter an address. It will say street first or city first (enter) right side will say sym or 123. you can toggle between the two. If you can find a manual let me know please.
Navigon 2000S... | Answered on Jan 21, 2017
Hi
There is a possibility that the antenna is defective. Sometimes a factory reboot helps or re-burn of the firmware. One way to confirm an antenna problem is to go into the tools menu and select "about". If the screen says "GPS S/W = 0.0 (should be a real number like 2.9 or 3.0) then this indicates that your antenna is not communicating with the main board.
http://www.sharc.net/gps_antenna_repair.htm
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Navigon 2000S... | Answered on Mar 24, 2011
U will find that the price of the screen if avail is more than the GPS cost and will only be avail (which i doubt) from the manufacturer
Navigon 2000S... | Answered on May 19, 2010
software try to restore it call the company or search their site
Navigon 2000S... | Answered on May 08, 2010
Here is a link to the page on the Navigon web site where you can download the manual you need.
http://support.navigonusa.com/support/index.php/userguides
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Navigon 2000S... | Answered on Apr 29, 2010
First you need to set your home adress as one of your favorites. Then set it as the home adress.
This is on page 62 and page 76 of the manual. It has a step by step.
http://support.navigonusa.com/_pdf/manual/Manual_2000S_2200T_Series_English_Rev1_1.pdf
Navigon 2000S... | Answered on Apr 04, 2010
Your navigon gps system should of have came with a cd with the drivers on it. If you didnt recieve it visit the manufactures website. Check the Drivers and Downloads Section.
Navigon 2000S... | Answered on Mar 11, 2010
Here is a link to navagon. Click on product user guids and scroll down to your model.
Navigon 2000S... | Answered on Sep 25, 2009
Well after many emails to Navigon I got the fix for my 2000s What you have to do is download the 1.2 version software for the 5100 install it on a 2GB micro SD Card. Put it in the slot and turn it on. You will have to regester as if you have a 5100 but it will work. The reason you have to use a 2GB card is the maps are to large to go on the internal memory.
Navigon 2000S... | Answered on Aug 21, 2009
looking with the screen towards you, on the right hand side of the gps near the top is a reset
Navigon 2000S... | Answered on Jul 09, 2009
Caution! Selecting the (Cancel) button during these steps will cause the
NAVIGON device to cease operation and will require the user to reset the device.
First Time Startup
When you first start your device, the LANGUAGE SELECTION WINDOW displays.
1. Select the appropriate language and tap OK.
The DISTANCE UNIT SELECTION WINDOW displays.
2. Select either Kilometers or Miles and tap OK.
The CLOCK SETTING WINDOW displays.
3. Select either 12h (am/pm) or 24h and tap OK.
The selected options will be used by the device.
did you try reset to get back to the first time setup as posted above?
Navigon 2000S... | Answered on Jun 19, 2009
Hi!
Basicallly, go to google.com, then in search area TYPE press first the image, then type in the Puerto RIco Map then enter.. after you see the pictures or map, point your mouse to the MAP of Purto RIco the right click after right click press copy then go to the desktop and press control V meaning paster. after that you have to double click the file the you can open it in Photoshope or Paint.. Good Luck & Regards
Ronie
Navigon 2000S... | Answered on Mar 18, 2009
Navigon 2000S GPS Receiver Logo
Popular Tags
25 questions posted
Top Navigon GPS Experts
Marvin
Marvin
Anthony Ward
Anthony Ward
Are you a Navigon GPS Expert? Answer questions, earn points and help others
View Most Popular
Navigon GPS
  • Navigon GPS
Most Popular Question
navigon 2000s cannot reset navigon 2000s
  • GPS
