20 Most Recent
Garmin Nuvi 760 Car GPS Receiver Questions & Answers
NUVI 760 2010 MAP UPDATE ERROR CODE 2
The easiest solution is to put an sd card (8gb or less) into the sd slot. Have Garmin Express install to the sd card.
You can also do a hard reset and try to install to the device itself. A hard reset restores the files to factory default, so it may free up enough space.
How do I change a route on my garmin rv760 from the route the gps picks
There should be a built in trip planner app to set up your trip. If it is a long trip and you don't like the route just add a stop for gas or food along the route you want to take. If it is a short trip then get over the fact it is recommending something different, mute, it and drive how you want to go. It is a computer and does not know what you may know. As an alternative, add a via point by telling it a new destination while it already has one. For via points remember to work backwards. Final destination, then next to last and so on.
My nuvi 760 routes me the long way around
You should do the following: Changing the Navigation Settings;
Touch Tools>settings>Navigation. There you'll find how the sysytem will calculate your route.Route Preference.........Faster Time....Shorter Distance.......Off Road....Avoidances,very helpfull....Restore original navigation settings.
Hope this will help you,
JADF
Touch screen doesn't work sometimes
In that case, the touch screen is faulty and must be replaced; it's a fairly common fault and your faulty screen cannot be repaired. If you search YouTube for "Nuvi 760 battery replacement" you'll see how to dismantle your machine.
The screen is not hugely expensive and not difficult to fit, and as you obviously realise you'll need to enter the diagnostic menu after fitting to recalibrate the screen (for those reading this who are unfamiliar with this, press and hold the battery icon to access the diagnostic menus).
Although the screen isn't that expensive, consider whether to replace the battery at the same time as it's probably seen better days. But when you add the cost of the screen and the battery then if the maps on your machine are out of date then it's going to make more economic sense to buy a complete new machine.
