20 Most Recent
Roper RTW4300SQ Top Load Washer Questions & Answers
My Roper Washer RTW43405Q0 won't spin.
For the washer to operate the lid must be fully closed, the timer must be pulled out, and the water must be drained.
The main causes for not spinning are:
Lid partially or completely open
Lid or other object has hit the timer knob and turned the washer offLid not locked (by the way, not on all washers) and may be not draining.
Make sure the lid is completely closed. Make sure that no clothing is in the lid area.
Make sure the Timer knob is pulled out.
The lid must be closed and locked for the washer to operate. Once the lid is closed, make sure the desired cycle is still selected and then press the Start button and listen for the lid to lock.
Make sure there are no loose metal objects such as coins and paper clips in the lid opening area. Metal objects can prevent magnetic switches from reacting correctly when the lid is closed.
If the washer has not drained, it will not go into spin.
Hope this works.....
