20 Most Recent General Electric WCSR2090G Top Load Washer Questions & Answers
0answers
How to take apart will not spin out the water
I don't know your particular washer, however, have had some experience with a couple of others. I found that something got caught in the flow line to the pump (in this case one of the plastic clips that holds a bread bag closed). I tipped the washer on its side and removed the pump so I could find the blockage. The location of the pump/outlet hose will be differrent on all washers and models, however, with it tipped over or with the front or possibly the back removed it should be able to be located.
11/23/2011 2:59:25 PM • General Electric... • Answered on Nov 23, 2011
Water leaked out of the unit but not through the
Sounds like 1 of the following:
  1. Clogged drain pump
  2. Clogged drain tube
  3. Clog in the plumbing where drain tube empties
10/16/2011 3:58:02 PM • General Electric... • Answered on Oct 16, 2011
My daughters washer does not shut the water off
it is number ten in this diagram http://lookup.bellparts.com/diagramenlarge/ge/113558/00128471.i01
the hose may have came off either at the tub or pressure switch. to open the panel there are three screws on the top back of the control panel then the control flips forward. make sure the hose is connected at both ends.
6/6/2011 8:19:25 PM • General Electric... • Answered on Jun 06, 2011
0answers
My GE washer drains as it is filling but the spin
The standpipe that the drain hose drains into is too low. Make sure your drain hose is at least 36 " high.
10/10/2010 4:25:36 PM • General Electric... • Answered on Oct 10, 2010
Burning smell after the final spin cycle is
you have a problem with the belt its happened to me
3/21/2010 9:32:26 PM • General Electric... • Answered on Mar 21, 2010
2 problems 1st is the washer continues to fill
If the water keeps filling without cutting off, you either have a faulty inlet solenoide or your pressure hose and or pressure switch needs checking.
To isolate the acutal problem, start the machine on a new cycle. Change the water level to minimum or low before you start. Let the machine fill up. Keep checking the water intake as it fill up. Once the water level goes over the half way mark in your tank, if the machine starts its wash action then your pressure hose and switch are o.k. as they have signalled to the timer that the water level selected, has been reached.
However if the machine keeps filling up even though the wash action has started, then you have a faulty inlet solenoide/valve. Turn off water at the tap and get the valve replaced.
Ash
10/26/2009 2:30:29 AM • General Electric... • Answered on Oct 26, 2009
Dial on the washing machine is broken
how do i open a WSCR2090g top load washer
9/26/2009 11:32:53 PM • General Electric... • Answered on Sep 26, 2009
My General Electric W66 washing machine is plugged in but does not switch on. Why?
A fuse might of had blown or a there is a problem with the circuit breaker. Or the motor cold be broken for the washing machine the main control board could be having issues that controls the washing machine and allows it to work.
4/14/2022 7:29:04 AM • General Electric... • Answered on Apr 14, 2022
2answers
General Electric portable washing machine.
Question edited for clarity. Better known as 'space saving' washing machines, they are a compromise at best. Try presoaking the clothes overnight. Do longer programs. Try changing detergents. Wash twice.
3/22/2022 2:31:47 PM • General Electric... • Answered on Mar 22, 2022
Why does my new belt on my General Electric Washer GTWN4250M1WS keep coming off
Streched belt or badly adjusted. There is not idler pulley and spring, so adjustment must be from the motor. Zooming in, the drive pully is smooth and has no channel and wall to keep the belt in place. The pulley must be slightly crowned in the middle which centres the belt, but if it is the lightest bit loose, it will derail. Almost designed to fail!. That is a really bad design.https://www.geapplianceparts.com/store/parts/ModelSectionParts/GTWN4250M1WS/4/0/0/0/SUSPENSION,_PUMP_&_DRIVE_COMPONENTS..
10/27/2021 11:32:07 PM • General Electric... • Answered on Oct 27, 2021
General electric Washer gtup270em0ww
Pumping out or leaking out? There are various rubber connectors underneath and they can perish and leak. There is a trick. slide a piece of paper under it. Switch on and after a minute, pull the paper out. It will give you a rough idea where the leak is, front, back, left or right. Then pull the machine out, and tilt it safely against the wall, get someone to hold it and look with a flashlight for the area where the wet patch on the paper was. Parts https://www.google.com/search?q=ge+gtup270em1ww+parts ..
7/12/2021 10:44:24 PM • General Electric... • Answered on Jul 12, 2021
I have a GE Adoration WHDRE526E1WW top load
It really sounds like the belt. You say it's in good shape but if it's loose or shiny from not having proper tension it wont have enough friction between the belt and pulley to actually work. If you've ever tried to move the drum when its full of clothes and water you know how much force id needed to function. Double check that belt tension and working surface.
9/1/2018 4:16:49 AM • General Electric... • Answered on Sep 01, 2018
General Electric WCSR2090G Top Load Washer Logo
17 questions posted
Top General Electric Washing Machines Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • General Electric Washing Machines
Most Popular Question
burning smell after final spin cycle
  • Washing Machines
