20 Most Recent Lexmark X4875 All-In-One InkJet Printer Questions & Answers
0answers
Installing printer
What is the Operating System on your Computer? Is that a Windows 8, Windows 7 Etc?
5/13/2013 6:00:16 PM • Lexmark X4875... • Answered on May 13, 2013
Thick black line through page when copying or scanning
Sounds like part of your scanner is not functioning and reading black all the time. Probably best to return it for a replacement.
Steve
10/9/2012 5:55:55 PM • Lexmark X4875... • Answered on Oct 09, 2012
Lexmark 4800 lost wireless connection with windows 7
Wireless communication issues could be due to wireless signal quality, signal interference, firewall, etc. Make sure your printer is positioned where it receives excellent wireless signal strength (avoid physical obstructions whenever possible) and away from appliances which emit wireless signals (e.g. microwave ovens, cordless telephones, baby monitors, and other wireless electronics) that may cause interference. Make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
1/28/2012 8:46:47 PM • Lexmark X4875... • Answered on Jan 28, 2012
How do I turn print
The Lexmark X4850-X4875 User's Guide can show you the step-by-step instructions on how to use the 2-sided printing function.(go to page 54)
6/1/2011 11:08:16 PM • Lexmark X4875... • Answered on Jun 01, 2011
Running Leopard Snow OS 10.6.7 and Lexmark X4875
You can download the Lexmark 4800 Series driver from the Lexmark website at http://bit.ly/hjWPTi. However, for the Lexmark OCR scan software, that can only be installed using the install disc that came with your printer. If you lost the disc, please contact Lexmark technical support for additional assistance.
5/3/2011 9:34:16 AM • Lexmark X4875... • Answered on May 03, 2011
Reset entire printer?
This article from the Lexmark website on How to Clear the NVRAM on a Lexmark X3500, X4500 and X4800 Series All-In-One will help you reset the printer to its factory default settings. Hope this helps. Thanks.
1/23/2011 9:22:43 PM • Lexmark X4875... • Answered on Jan 23, 2011
Printer keeps telling me that paper is jammed, but
Even the tinest piece of paper can cause this and also a sensor needing cleaned. Take a small flashlight and examine every nook and cravice of the computer. You may find a piece of paper. Take a lint free cloth and clean inside the machine as well and then try it.
6/18/2010 11:14:06 AM • Lexmark X4875... • Answered on Jun 18, 2010
When it scans it leaves a black line on the
The black line is either caused by dirt build up on the scanner glass (clean the scanner glass) or one of the bulbs on the scanner lamp is burnt out.
3/24/2010 6:04:02 PM • Lexmark X4875... • Answered on Mar 24, 2010
I have upgraded to Windows 7 from Vista. My
you have to open bios at start up to turn that back on
1/17/2010 2:31:16 PM • Lexmark X4875... • Answered on Jan 17, 2010
Lexmar 4875 Flatbed Wireless printer not connecting to the networ
I know you posted this in May, so have probably given up and bought a new printer by now, but I thought it worth mentioning that I had the same problem exactly (though without the same number of iphones and laptops!).
Buried away in some documentation on the driver CD, is the fact that the X4875 can't communicate with a secure wireless network that uses a TKIP algorithm - it can only handle AES. My router used TKIP out of the box, and I never thought to change is, especially as it's stronger than AES. However, changing it to AES solved the problem.
By the way, if you're using Vista, you may find that you have to run the install package in Windows XP compatibility mode, and then when the install is complete, manually change every .exe under c:\program files\lexmark\.. to run in XP compatibilty mode too. Works for me (Vista Business), but didn't work wirelessly at all before. Good luck,
Chris J.
7/13/2009 9:26:30 PM • Lexmark X4875... • Answered on Jul 13, 2009
I just switched to Verizon DSL from cable and now
Most likely the change in providers resulted in a change to your internal IP addressing scheme. First, make sure all of your devices have been power-cycled since the change to ensure they are using a valid IP for your network. Then, go to Control Panel -> Printers. From here, Add a Printer and select the Network or Wireless printer and allow Windows to search for your device. It should detect it and add it to your system. You can delete the old printer from the list once you have confirmed it is working properly.
7/6/2009 2:11:02 AM • Lexmark X4875... • Answered on Jul 06, 2009
Cannot print with Lexmark x4875, Windows Vista OS.
You need to cancel all print jobs for a printer, you must have permission to manage documents on the printer.
1. Open printers by clicking the "Start" button , clicking "Control Panel," clicking "Hardware and Sound," and then clicking "Printers."
2. To open the print queue, double-click the printer you are using.
3. Click the "Printer" menu, and then click "Cancel All Documents." Depending on the printer, the item currently printing might finish, but the remaining items will be cancelled.
Next, you may have to change the communication format called the "Spool format."
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 4800 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
If this does not help the situation, please describe any differences it does make.
4/19/2009 4:24:37 AM • Lexmark X4875... • Answered on Apr 19, 2009
Lexmark X4875 All-In-One InkJet Printer Logo
27 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
turn print
  • Office Equipment & Supplies
