20 Most Recent
Brother DCP-585cw All-in-One Wireless Color Inkjet Printer Questions & Answers
Printer offline and cannot get
Try this:
1: Go to start
2: printers and faxes
3: Right click on printer
4: Click on work offline ( this will put the printer online)
You are ready to go.
Hope this helps.
Regards,
3/17/2021 7:39:19 AM •
Brother...
Answered
on Mar 17, 2021
Brother DCP 585CW unable to
A possible reset might solve hence remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
8/19/2012 5:24:13 PM •
Brother...
Answered
on Aug 19, 2012
New ink colour printer not printing black. Prints
Hi there!
If the test page from pc or the machine test page doesnt show black, what you can do is to clean the printhead. To do that press the Ink Management button on the control panel and select cleaning press ok then press the up or down arrow key to select Black press ok and press Black Start. After the cleaning process print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times.
Hope this helps
Please rate if it worked
Thanks!
3/28/2012 8:02:54 AM •
Brother...
Answered
on Mar 28, 2012
My printer is no longer
Did upgrading your network to BT Infinity involve installing any software on your computer? If so, there could be issues with the
BT Infinity software resetting (erasing) your printer configuration and/or installing a new printer driver or setting a new (invalid) printer as the default printer on the system (thus routing all your printouts to the spool area for a non-functional printer).
To check this:
START> Control Panel> Devices and Printers
Did BT (British Telecom) install FTTC (Fibre to the Cabinet), with copper to the home, or did BT install FTTH (Fibre to the Home)?
9/29/2011 8:57:16 AM •
Brother...
Answered
on Sep 29, 2011
Printer will not comnnect to
People usually think connecting a printer via wireless is as simple as connecting a PC. However it is not the case. A printer need to communicate with every PC in the same internal network, however each PC will not communicate with other PCs in the same network to protect it private files and also the firewall settings. Next every PC is set to get a dynamic new IP address from the DHCP server everytime when it is powered up and plug into the network. But the printer need to get the same fixed IP address when it is powered up in the LAN.
So the Printer in a LAN need to set up a fixed IP address such that everytime when it is powered up, it has the same IP address that each PC could still get communicate with this Printer. Apart from setting this in the Printer, you also need to reserve this Fixed IP address with your Printer's MAC address in your DHCP server of the router. Otherwise it will get conflict with other PC or device that could have assigned the same fixed IP address. Then you have to setup your Firewall of your PC to let communication to this Printer. Else it will be blocked.
Lastly make sure you install the printer driver correctly in your PC with the same Win OS version such that it could detect the fixed IP address of your printer. Then it should work correctly.
Please let us know any problem you may have in future.
9/21/2011 2:52:57 AM •
Brother...
Answered
on Sep 21, 2011
I am trying to re-install my brother printer
There may be a issue here that you have not unistall the original program before attempting to reinstall the new program.
If you have done this and still get a problem, you should go direct to Brother's web site to download the latest driver version that corresponds to your Windows OS such as XP, Visita, or Win 7.
9/21/2011 2:25:31 AM •
Brother...
Answered
on Sep 21, 2011
I took my printer home
You have to check whether your printer was set up as a network printer or just a one to one printer in your workplace.
If it is a network printer, please check with your IT administrator whether it was set up with a fixed IP or using dynamic IP. After get these details, just set it up same as in your home network.
9/21/2011 2:22:50 AM •
Brother...
Answered
on Sep 21, 2011
Black not printing after replacing
You will need to have the print head replaced to fix this common problem. You can call brother at 1-877-brother and they will tell you what to do to get it repaired at no cost to you.
8/30/2011 9:35:06 PM •
Brother...
Answered
on Aug 30, 2011
THE BLACK INK STOPPED WORKING ,SO I GOT A NEW ONE
Recently, I had a similar problem which turned out to be faulty non-original ink tanks (cartridges) - they had a valve which was supposed to allow air to be drawn in as ink was drawn out. It turned out they had "gummed up" and weren't allowing air in, so once a small amount of ink had been drawn out a partial vacuum was created and stopped the flow of ink.
If fitting new, original ink tanks and running the cleaning routines a few times doesn't fix the problem, then this could be several things, some of which may mean your machine will have to be repaired by a Brother agent (probably cost you more than a new one), and/or it's time to bin it.
However, sometimes it's just because the print head, or the pipes that connect the ink tanks to the printhead, have become blocked with dried out ink.
If you search on YouTube, you will find a few videos that show how to clear such blockages - you may not find your exact model number, but many Brother machines use almost identical components to many others so the basic technique will be the same. Also search on Ebay for printer cleaning/head blockage kits - quite a few printers (not just Brother) suffer similar problems and a few businesses have sprung up on EBay that sell kits to help you sort this. They sometimes have links to a video they have produced showing how to use the kit which can give you ideas. Again, your exact model number or even make might not come up but these kits might be adaptable to your machine. Got to be worth a tenner or so before binning it ! Good luck
4/2/2011 4:34:26 PM •
Brother...
Answered
on Apr 02, 2011
A small white plastic piece has broken off the
In my experience, what you say might be correct. The small white broken piece could be the arm that comes down and touches the top sheet of paper in the tray, so it knows how much paper is loaded. When there is no arm, it can not recognize that there is paper loaded, thus NO PAPER FEED. I have fixed one of these in the past, but I had 2 identical printers to mix and match parts. I am not sure what it will cost you, you would have to call the repair center and find out. It took me about 2 hours to fix, so I hope a professional could do it faster than that.
3/14/2011 5:20:43 PM •
Brother...
Answered
on Mar 14, 2011
My Brother 6490 will not
Try to clean the print head from the panel of the printer,if the problem persist change the prin head because is clogged.
3/9/2011 10:24:26 PM •
Brother...
Answered
on Mar 09, 2011
