20 Most Recent
ASUS Essentio Desktop with Intel Pentium Dual-Core Processor E2200 Questions & Answers
How to hook up my
Plug in the stereo jack from your speakers into the sound card audio out . Assuming you have a stereo jack on your speakers, other wise you might need to buy a stereo jack with cabling which you will need to hook up to your speakers,
Asus essentrio series monitor wont
Loose contact in power supply or the video socket at the desktop or the monitor. Just move the cable around and if the problem recurs then it's either the power or video cable problem.
I am not a Computer
You could try going into the internet tcpip settings when it is working properly.note every field values down. After update go back to tcpip settings and manually enter every value and save. It should work.
Where to get drivers downloads
From here. You will need to enter the model number (not name) and your operating system
http://support.asus.com/Download/Options.aspx?type=1&SLanguage=en
No sound but signal work
plz check proper connection,if it is connected properly then go to sound setting and select the HD Audio/Headphone whatever you are connected.then this will work.
ASUS Essentio series CMA 51AC--- after running for
What are the circumstances: Programs running, temperature of room, position of unit, surface sitting on, Sounds like it is overheating or ram is failing for starters. Got this off consumer reports: By NatT96from Los Angeles, CA(2 of 2 customers found this review helpful) 2.0 Limited Performance (DO NOT BUY) 8/23/2013 Pros Adequate Storage Quality Accessories Sleek Design Cons Ignored Boot Mgr Issue Overheating Poor customer support Poor Graphics Card Restarts Randomly Unreliable Performance Best Uses Internet Music Video Word Processing Comment:Got this PC as a gift. After two months of developing a large Android-based application project and playing high performing games on the computer, I have found out that the graphics card has already malfunctioned(Overheats), causing the PC to restart! Now get this, I called ASUS once and the person on the other line told me to back up a large hard drive to CD's.....seriously.The next day I called I told them that even Videos, Unity Pro, and Games on the PC simply restarted it over and over again. So what I was told is to by to a System recovery and go back in time on the computers main hard drive. Did not fix the restart issue.
Cpu temperature error
Turn off PC, Unplug PC from power. Open PC case. Examine all fans including CPU fan and heatsink. clean the fans and heatsink. With case open but everything inside connected properly, Plug pc back in. Power up the PC and check that all fans are running. If not replace fan that is not running. Place PC in a well ventilated area when operating. I use a new small paintbrush for cleaning dust from inside of PC.
I am having a problem turning on my new ASUS
Well let me give you a better idea what may be happenig.
First off Do you feel the fan blowing air out in back of the computer? If so continue below if not you need a power supply.
Next do you hear any of the normal beeps or sounds during start up,
It is possible for it to be on but not loading post (power on self test procedure) if so then continue below if not check cmos and hard drive.
Do you know if your monitor is good? Do you see green light on front? Check connection to computer? It's possible your computer is running fine but you can not see it due to bad monitor? Do you have a spare monitor you can try? Have you tried pulling out video card & reinserting it?
Please let me know the status of the above and I will cvontinue with you after these answers.
Thanks,
Scott
