20 Most Recent
Lenovo IdeaPad Y530 Laptop Questions & Answers
Lenovo laptop screen resolution
Which resolution are you trying to set?
You should be able to set the maximum for the laptop: 1280 x 800.
If you cannot set this resolution, then make sure that you are using the Lenovo drivers, and not something Windows update installed.
Lenovo idea flexpad 20
1. Check for a bad battery. This is the most common problem for mobile devices like tablets, laptops and the like. Since the battery must be fully functional (at OEM specified outputs for volatage and current) for the device to operate (manuf. designed it that way to protect the circuits years ago), it is the most likley culprit. (FYI: I have two Lenovo laptops - one under the old IBM Thinkpad label and one newer Chinese Lenovo).
* Replace the battery with a new OEM replacement as I do not recommend after-market generics or refurbished)
2. Try a different power supply. Check the OUTPUT requirements on your existing power adapter (usually 5v) and locate a another adapter to see if it is the AC adapter. The only real issue you need to worry about is the OUTPUT voltage must match the original adapter to avoid damage. The current does not matter since the device determines how much current in mAH it requires so just concern yourself with the right OUTPUT VOLTAGE and the jack plug makes a proper fit. If a spare adapter is not available (Radio Shack sells a variable voltage adapter with a variety of interface plugs and they work very well for these issues) then try using the Lenovo adapter on another device. (I am assuming you do not have electronics tools or test bench and need to troubleshoot the old school way)
* Replace the dead adapter ensuring that the VOLTs are the same on OUTPUT as the original and the interface plugjack is the same size.
If, after doing the above two simple steps, consider that the MB (mainboard - motherboard) power supply is toast and the laptop is good for recycling only
There is is no battery on this lenovo
If as you stated that there is no battery on this Lenovo then i would say that is why it will not power on, if you mean the battery is not holding a charge then the battery will need replacing as with most tablets they will not operate on the mains power alone, it needs a working battery.
Laptop won't turn on
Remove main battery and try again, have the power supply adapter checked, the DC jack in the motherboard is another source of trouble from no power to intermittent operation, at this point the laptop must be dismantled to down to the main board to address the issue.
Hi all,
when I press Fn+F3
The Fn+F3 key toggles between these display settings when you press these keys again.
To the external projector only.
To both the external projector and laptop screen
To the laptop screen only.
Repeat pressing the Fn+F3 keys will cycle through these screen settings again.
Key board problem
You have the numlock pressed. Look for its key in the top right, and change it so the display for numlock is turned off.
I have lenovo ideapad Y530.
Lenovo? Oh, it must be having face recognition, right? Maybe your inbuilt webcam is continuously being used by the biometric software.
HOW TO EJECT A DISC IN LENOVO IDEAPAD 330
The CD/DVD drive may be opened by pressing a button on the drive itself. If the drive does not open by pressing a button on the drive itself, or the button is not available on the drive, Windows natively provides the ability to eject the tray with simple methods that can be performed in the File Explorer. The steps vary from different operating systems:
Note:
- Not all systems come with a CD-ROM, CD-RW, or DVD drive installed internally to the computer
- To verify that, you can check the left and right side of your machine. See if there is any slot to insert your CD/DVD. Normally, there is a button to eject the CD or DVD tray for you to insert a disc
- Another method to identify this is as below:
1. Click Start and type Device Manager in the search box. Select Device Manager
2. In Device Manager look for DVD/CD -ROM Drives
If you don"t see DVD/CD -ROM Drives this means your device has no optical drive hardware. An external optical drive will need to be purchased to run CD/DVD. It is also wise to check your product specification to see if your device has an optical drive.
If you were previously able to play CD/DVD and DVD/CD -ROM Drives has disappeared from device manager or your device is not reading the disc please follow > Your CD or DVD drive is not recognized by Windows or other programs.
- The format capabilities of the drive are listed on the label on the external cover of the drive
- The CD-ROM, CD-RW, or DVD drive can be opened using the emergency eject hole (Bend away a leg of a paperclip to work with. Insert the paperclip slowly until there is resistance, then gently push until the drive door is opened) Applicable Brands
Solution
·Windows 10
·Windows 7 Eject disk tray with File Explorer
- Turn off all applications currently using the drive. Otherwise Windows will prevent you from ejecting the DVD tray
- Hold Windows + E on the keyboard to open File Explorer
- Click the DVD drive icon and click the "Eject" button on the toolbar or right-click on the optical drive and choose Eject from the menu that pops up or down.
Win 10 lenvo ideapad 320 will not play mygames now
really why not ask the game maker directly for help with your w10.
here they are right>?
https://www.mygames.com/
so what do THEY say , it is there code, running.
does Tetris fail or just your games, unnamed,
this maker is bad company they take over your PC
why run this crappp? it takes over your browser,
and more,
and is bad.
the do not even have minimum system requirement there.
nor support. avoid like the Plague.
