20 Most Recent
Sony Cybershot DSC-T77 Digital Camera Questions & Answers
How can i change it ?
To change the language, touch HOME instead. Select the toolbox icon, then select the last item on the menu.
I WANT TO DOWNLOAD THE DRIVER OF DSC-T77 DIGITAL CAMERA
You don't need a driver. But if you really want a driver, look
here.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
There is pictures in the camera, but laptop not able to detect the files. It says 'An error is prevents the photo or video from being displayed. Error Code: 0x80010108
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or
Picasa.
How to down load pictures
ok u hav some options:
> use ur usb cable
> take out ur memory card, buy USB CARD READER OR A LITTLE USB THAT U CAN PUT MEMORY CARD IN then either put in correct slot or put in the dongle and plug in comp voila!
I am not able to
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa ( http://picasa.google.com ).
I have sony cybershot T77
If it's really inside the lens only Sony can clean that up.
An ordinary cam repairman cant open up the lens.
Only Sony has the tools for it.
I wan changne language japan
Touch HOME to display the Home screen. Touch the toolbox icon. Select the last item on the menu. Select the desired language.
How Can I change language
Touch [HOME] to display the Home screen. Touch the toolbox icon. Select the last item on the menu. Select the desired language.
I have Sony DSC-T77 Cypershot
