20 Most Recent Agfa Cyber-shot DSC-W150 Digital Camera Questions & Answers
Need a instruction booklet for
You can download and print the instruction manual for Sony Cybershot W150 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Thanks for using FixYa.
1/4/2015 9:16:55 AM • Agfa Cyber-shot... • Answered on Jan 04, 2015
I have a sony cybershot DSC-W150 digital camera.
The message may appear when the camera detects an excessive pressure on the lens leading to a lens malfunction. If turning the power off and on again does not resolve the issue, do a POWER RESET. If the problem persists..> Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens.Try "gently" tapping around the lens barrels with a small item such as a pen or pencil.
10/17/2011 12:57:57 AM • Agfa Cyber-shot... • Answered on Oct 17, 2011
My camera was dropped and now the screen is
The screen can be replaced, but I would recommend a camera repair shop to do the job and to make sure there are no other issues.
1/21/2011 1:58:46 AM • Agfa Cyber-shot... • Answered on Jan 21, 2011
I dropped it and now the zoom lens will not come
its motorised retractible spindel you need to take it in so that thay can reclip the coil
1/6/2011 5:34:56 PM • Agfa Cyber-shot... • Answered on Jan 06, 2011
When i turn my camera
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Agfa service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
10/2/2010 3:06:00 PM • Agfa Cyber-shot... • Answered on Oct 02, 2010
I have a SONY Cybershot DSC W150. When I turn it
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/13/2010 12:58:07 AM • Agfa Cyber-shot... • Answered on Sep 13, 2010
Cannot take pictures
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
9/11/2010 3:25:42 PM • Agfa Cyber-shot... • Answered on Sep 11, 2010
I have a Sony Cybershot W150. I have already had
Ok David, be persistant with this seemingly kludge of a fix.
Use a can of compressed air and blow around the lens while it is extended. Take a relatively firm approach with this problem slap the camera into your palm two or three times.
Not lens down in this case, but using the side or rear of the camera to make contact with your palm
Make sure you have the camera cord around your wrist so as not to lose it across the room.
Do this several times and turn it on and off till the message of turn on and off no longer shows(if it ever did) and the lens retracts and works correctly. The compressed air will help remove any accumulated dust that is jamming the lens.
This is a sony tech fix and not a joke, they charge you $90-120 to do this and this fault is not uncommon in many of these small cameras
dust and dirt get taken into the lens bay and eventually cause it to stick. Hence the use of compressed air with the brutal approach
I have fixed around 200 of these over the last 2 years using this method. only 3 failed to respond
Please rate my help++++Thyanks for using FIXYA
9/2/2010 12:57:12 AM • Agfa Cyber-shot... • Answered on Sep 02, 2010
2answers
Lens do not retract to original position whether
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
3/9/2010 4:55:33 PM • Agfa Cyber-shot... • Answered on Mar 09, 2010
Sony DSC-W150 turn on message and camera won't work
The fix should have been guaranteed for a period of time. If that hasn't expired, contact the company and demand they make good on their work.
2/14/2010 4:15:14 AM • Agfa Cyber-shot... • Answered on Feb 14, 2010
Why does my DSC-W150 digit camera say
Tried a new battery the same as the old one
10/24/2009 11:03:45 AM • Agfa Cyber-shot... • Answered on Oct 24, 2009
Power error message
I followed the advice of the other posts, about the lens just being stuck. I tried the tweeze and blow, and the gentle turning methods. Neither did the trick. I went to the "pull the thing out, if it breaks, well it wasn't working anyway" method, and voila! Okay, so I broke a little piece of the lens sliding lens cover...but at least I got to take the pictures of my daughter and Cupcake the Teddybear for her school project. Thanks everybody for the help.
10/9/2009 12:37:36 PM • Agfa Cyber-shot... • Answered on Oct 09, 2009
I have a sony cybershot DSC-W150, and for some
Hi, Lens requires manually restting. If you in the U.K , I can help you out.
p.m me at [email protected]
8/11/2009 7:13:20 PM • Agfa Cyber-shot... • Answered on Aug 11, 2009
Sony cyber-shot dsc-w150 display always reads "remaining shots 4"
In the menu you most likely have the size size at or near maximum. This uses up a lot of space on your card. Try reducing the size.
7/17/2009 9:03:26 PM • Agfa Cyber-shot... • Answered on Jul 17, 2009
Agfa Cyber-shot DSC-W150  Digital Camera Logo
28 questions posted
Top Agfa Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you an Agfa Camera Expert? Answer questions, earn points and help others
View Most Popular
Agfa Cameras
  • Agfa Cameras
Most Popular Question
sony cybershot dsc w150 digital camera
  • Cameras
