20 Most Recent
Samsung SCX-4321 All-In-One Laser Printer Questions & Answers
What is errer #u1 2320
Dear Its related to fusser temp. Check the fusser assy. thermostat it may open . either it may reset or replaced with new one. The error code mean-OPEN HEAT ERROR.
thanks
Paper jam 2 error in scx 4321
is this there all the time or only when you try to print? if it is there all the time there is a paper jam in the fuser area the back of the machine. if it only happens when you try to print it is most likely the feed tires in the paper feed in area.
Samsung scx 4231 printer coming blank page
did this only happen after you changed the cart or is this why you tried a new cart? if it only happened after you changed it try a new on you could have gotten a bad one. some times they do not connect up with the pins inside the machine
#1317 error
According to samsung tech support its a paper jam...check and remove the paper or piece there of.
