20 Most Recent Lexmark X7675 Wireless All-in-One Printer Questions & Answers
No solution here - just confirmation. Mine say that it (the scanner) cannot save files to my hard drive, that it is full. That's far from true, but to a dumb accessory a locked target folder/directory will look like a full disk. Does anyone know where Lexmark parks it's temporary files? I've looked in all the usual places on my Mac, and can't find anything yet. (I have previously found a Brother parks it's initial scans, before you save them, deep in a normally inaccessible corner of the System folder.)
Lexmark X7675... | Answered on Sep 17, 2015
Most printers you go into your computer where your printer is listed, find the printer right click mouse or pad, and you may see a line that says off line, click on it and many times it puts it back on line...
Lexmark X7675... | Answered on May 08, 2014
I dont; have the book for my printer, lexmark x7675; I NEED HELP TO INSTILL IT
Lexmark X7675... | Answered on Apr 16, 2014
Tip
Where to find the manual (pdf) for Lexmark X7675 multifunction printer
Sometimes , it is convenient to have a soft copy of your user manual. You may also require it as you lost your original printed manual. This tip will guide you to your digital manual and explain how to download it.
Printed manuals are normally available at a cost from the product manufacturer. Please see the link below to contact the manufacturer and find out how to replace your printed manual.
To download a soft copy of your manual , please Click Here to go to the retrevo page for your manual. This is a excellent site that maintains a manual and product database of thousands of products available free to download in PDF format.
Please note that you will need pdf viewer software to be able to view the downloaded manual. I can recommend Adobe reader which is available for free download at the following location :
CLICK HERE to go to Adobe Reader download site.
To download you manual from retrevo , follow the above mentioned link.You will be taken to the product page. The following images are used as an example.
When your on this page , you can select to see reviews , prices , specs , an overview of the product and of coarse , the manual. You can just hit the big red manual button to proceed.
Now simply type in the capcha code and hit the red “download now” button to begin your manual download.
To go to the manufacturers website , click on the link below:
Canon USA
Canon Global
HP
Epson
Lexmark
Samsung
Brother
Please rate this tip if you found it useful.
Kind Regards
StephanSA
on Jan 09, 2014 | Lexmark X7675 Wireless All-in-One...
Hello. The cartridges may not be seated properly or just needs cleaning. Remove the cartridges from the printer. Make sure the protective nozzle tape is already removed. Wipe the nozzles of the cartridges using a damp paper towel. Unplug printer from power source, plug it back in after 10-15 seconds. When the printer's ready, reload one cartridge first. Close the cover, check if "out of ink" message is displayed. If not, proceed on loading the other cartridge. This is to check which cartridge is causing the problem. Try this steps maybe 2 or 3 times until the printer recognizes the cartridges. If problem persists, I strongly advise you to contact Lexmark at 1-800-LEXMARK(1-800-539-6275). You probably got defective cartridges.
Lexmark X7675... | Answered on Nov 08, 2011
It could be that the Print Spooler service has stopped. Please follow the steps below to fix the problem:
1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Lexmark X7675... | Answered on Aug 01, 2011
This article on the Lexmark website about Printer Cartridge Stalls or Is Blocked will help fix the problem you are experiencing.
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Lexmark X7675... | Answered on Apr 06, 2011
You may refer to this article in the Lexmark website on How to Change the Cartridges on Lexmark Inkjet and All-In-One Printers. The printer shown may not be your model, however the steps are the same. Thanks.
Lexmark X7675... | Answered on Mar 09, 2011
you have to open up the printer using a every day Phillips screw driver, once you have done that you either need to rotate the roller by hand or look for something stuck in rollers that you cant see under normal circumstances
Lexmark X7675... | Answered on Mar 06, 2011
Lexmark X7675 Wireless All-in-One Printer Logo
65 questions posted
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
lost disk
  • Office Equipment & Supplies
