20 Most Recent
Dell Laser 1720 Printer Questions & Answers
My dell 1720 printer prints streaks on the right
Remove the toner and the paper tray and open every door on the printer. Take a can of air and blow out every nook and cranny in the printer. Check and carefully wipe all rollers. There a fuser kit in the printer, likely in the back. If you feel comfortable with it, remove the fuser kit and use a can of air to continue cleaning. Reassemble the printer and run a few test pages, it may look like a bigger mess for the first few pages (up to 25). However, as you run the pages the print should clear up. If you still have a streaks on the pages, you will likely need to order an maintenance kit from dell. This kit should include the fuse, rollers and other replacement parts for the printer.I hope this has helped you
Black ink on right margin when printing
it can either be the imagine drum or the toner. If there are scratches or smudges on the imaging drum it can cause that problem, or if toner is escaping out of the toner cartridge. try removing both, I believe they come out in one piece and inspect.
How can i rest photoconduct kit is finished life
To resert drum counter, Use the following steps.
1. Open the front door.
2. Press and hold the cancel button (x button) until all the lights flash in in order.
3. Then close the front cover.
This will reset the drum counter so that you can continue to print.
Toner smudges along left side of document.
It is likely your drum unit that is defective. Replacing this should stop the smudging. Be sure to buy a high quality replacement. Original Dell or reputable remanufactured only. Be aware of the vendor's return policy and failure rate before you buy.
Are you ther
Please elaborate your problem providing us with more details like the make and model number of your product and the complete description of the problem so that we can provide you with the relevant assistance.
Thanks.
Are you there
Please elaborate your question and we will help you..
Please leave your Queries as a comment and we will help you
RNJ VINODKUMAR
Toner leaking ink on one side of paper pretty bad
There could just be a lot of toner inside the printer, but it could also be the drum unit (which also collects the waste toner) is so full that it is leaking.
This typically happens when the 'replace drum' indication is reset without actually replacing the drum.
If you have reset this without replacing the drum, and the print count is in excess of 30,000, you probably just need to replace the drm unit.
Laser 1720 printer leaking ink on the right hand help its a dell
Look at the toner cartridge.
There is a small plastic locking collar on the end of the spindle of the rubber Developer Roller (it's this that carries the toner to the drum). I'd bet that this locking collar is loose, misplaced, or missing.
Leaking toner on the right of the printer is usually caused by this.
The other possible cause is a partially detached seal underneath the Developer Roller.
Replacing Dell Laser printer cartridge 1720
Open the front cover by pressing the button on the left side of the printer and lowering the cover.
Press the button on the base of the toner cartridge assembly.
Pull the toner cartridge up and out using the handle.
Unpack the new toner cartridge.
****Rotate the cartridge in all directions to distribute the toner****
Install the new toner cartridge by aligning the white rollers on the toner cartridge with the arrows on the tracks of the imaging drum and pushing the toner cartridge in as far as it will go. The cartridge clicks into place when correctly installed.
Close the front cover.
