20 Most Recent
M T D Products MTD Gold 42" 19 HP Lawn Tractor Questions & Answers
No spark 19hp kohler
If the mower has been stored outside the magneto could have rust on it. Remove the top of the engine cover. There is a coil that's bolts to the block the the magnet of the magneto passes by as it rotates. See it there is rust on the magnet. If so. Take a fine grit sandpaper and remove the rust. The rust changes the air gap causing no voltage to the ignition coil. Thus no spark at the plug. I've corrected this problem twice with same symptoms as yours.
I've a 5 litre garden pressure sprayer and it's not functioning properly. It is pumping pressure but then it's leaking it all out at top of the green handle.
Here are some steps you can follow:
Check the Seals and O-Rings:
Release the pressure: Make sure there's no pressure in the cylinder by releasing the pressure release valve.
Unscrew the pump: Remove the pump to access the internal components.
Inspect the seals and O-rings:
Look for any damaged or worn-out rubber seals.
Check the rubber seal at the bottom of the tube (where the plunger sits) and ensure it's in place.
Examine the one-way valve (usually at the bottom of the tube) and clean it. Lubricate it with silicone grease.
Lubricate the rubber washer on the plunger with silicone grease and reassemble it in the tube.
Reassemble the pump: Put the plunger back into the tube and lock it with the handle.
Test the sprayer: Pump it up and check if it maintains pressure without leaking.
Inspect the Handle and Hose:
Handle connection: Ensure the handle is securely attached to the cylinder.
Hose inspection: Check the hose for kinks, twists, or blockages. Straighten out any kinks and remove debris that might be blocking the hose.
Check the Nozzle and Wand:
Nozzle adjustment: Adjust the nozzle to the desired spray pattern.
Wand inspection: Examine the spray wand for clogs or obstructions.
Lubricate O-Rings and Seals:
Apply silicone grease to the O-rings, seals, and other moving parts to ensure smooth operation.
Test the Sprayer:
Fill the cylinder to the desired level (avoid exceeding the maximum fill mark).
Screw down the pump firmly to create an airtight seal.
Manually operate the pressure release valve to ensure it's working.
4/23/2024 5:45:51 PM •
Garden
Answered
23 hours ago
What is the transportation ring on a huskvarna chain saw
The transportation ring on a Husqvarna chainsaw is a small metal ring that is sometimes fitted onto one of the bolts when the saw is new. Its purpose is to prevent the chain from rotating during transportation or storage. If your chainsaw has this ring, you should remove it before using the saw. Keep it in a safe place so you can use it again if needed. If you're looking for more information about Husqvarna chainsaws, you can refer to the operator's manual for detailed instructions.
https://www.manualslib.com/manual/3145215/Husqvarna-440.html
4/20/2024 9:45:09 PM •
Garden
Answered
3 days ago
What are some broadleaf evergreen weeping trees?
TreeKisan is a AI- based Platform where tree farmers can know the standing tree market valuation in just 1 minute and sell to potential buyers. Easily assess the economic potential of your trees and make informed decisions. Download TreeKisan Now!
4/17/2024 9:39:10 AM •
Garden
Answered
on Apr 17, 2024
Scotts lawn mower 21995x8b manual
I'm guessing you have fixed this or given up after 13.5 years, but here is my suggestion for the next person who has this trouble. If you ran it out of fuel and left it over the winter, it could have a drop of fuel that hardened and plugged one of the fuel ports in the carburetor. I have had this happen and needed to remove the fuel bowl and poke the dried film with a pin. Put it back together and it started right up.
3/31/2024 1:19:11 AM •
Garden
Answered
on Mar 31, 2024
Where can i find choke cable for 422707 model # riding mower.
Do not know what brand that is, but you can find choke cables at lowes, amazon .com. or any number of small engine repair shops depending on where you live. An after market cable could be easier to find and work just as well.
3/30/2024 4:44:30 AM •
Garden
Answered
on Mar 30, 2024
What are the advantages of using HDPE pond liner sheets for constructing a pond?
Here are the advantages of using HDPE pond liner sheets for constructing a pond:
- Durability and Puncture Resistance: HDPE is a tough material that can withstand wear and tear. It's resistant to punctures from rocks, roots, or other sharp objects that might be present in the soil under your pond. This translates to a long lifespan for your pond liner, minimizing the need for replacements.
- UV Resistance: Unlike some materials that degrade under sunlight, HDPE liners are UV resistant. This means they won't become brittle or break down over time when exposed to the sun, ensuring the liner lasts for many years.
- Chemical Compatibility: HDPE is non-toxic and resistant to many chemicals. This makes it safe for fish and plants in your pond, and it won't leach harmful chemicals into the water if you need to treat the pond with certain substances.
- Suitable for Large Ponds: HDPE liners come in large sheet sizes, making them ideal for constructing bigger ponds. The large sheet size reduces the need for seams, which can be weak points in a liner, and simplifies the installation process for larger ponds.
- Relatively Easy Installation: While professional installation is always recommended, HDPE liners are lighter than some other pond liner options and can be workable for DIY projects. They can be welded together to create a secure seam, and their flexibility allows them to conform to the contours of your pond.
- Cost-Effective in the Long Run: Although the upfront cost of HDPE liners might be higher than some other options, their durability and low maintenance requirements make them a cost-effective choice in the long run. You won't need to replace them as often, and they can help prevent leaks that could damage your landscaping or require repairs.
3/18/2024 7:08:38 PM •
Garden
Answered
on Mar 18, 2024
