20 Most Recent
HP Officejet Pro K5300 Laser Printer Questions & Answers
The printer
There are couple of things as reasons for this behavior of your printer.
1) First be absolutely sure that the cartridges you have inside are the ones meant for HP Officejet Pro k5300. The liquidity of the ink does create problems from catridge to cartridge.
2) The catridge nozzle and the print head needs thorough clean up as ink is not flowing out properly or there is a clogg. Try to use the print head clean up utility . You will find this from your manual. This happens if the ink is not good or the printer has not been used for some time.
3) Third which is also possible is incorrect set of drivers. Try to uninstall and install the set of drivers for the printer once again so that the properties and settings are defualt and command triggers all cartridges to work .
4) Hope the above steps resolve the issue else the last option would be to replace the black cartridge.
Thank You
Black won' print on pro
You could clean the
black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
How to reset printer hp offiject 6700
- If the user cannot solve an issue that has been troubleshooting frequently, then obviously the last thing would do is to reset the printer.
- To perform a reset, turn on the 123.hp.com/oj6700 printer by pressing the power button.
- With the printer turned ON, disconnect the power cord from the rear end of the printer.
- Remove the power cord from the wall outlet. Wait for a few seconds and re-connect the power plug back to the outlet.
- Reconnect the power cord to the printer's rear. If the printer does not turn ON automatically, press the Power button. for More visit https://goo.gl/t55XMJ Call Our Toll-Free 1 888 224 4280
Office jet pro 8710. will not print says the paper size detected 0 by the printer does not match the paper size selected (8.5x11in) for the print job
The Officejet 8710 printer can face paper mismatch issues if the paper settings are not set properly in the Print Preview box. Try setting the Paper Type option to Plain in the settings window that appears before performing the print. Change the settings to 8.5 x 11 in both the copier and the printer setting. There can also be an issue with the paper tray. Set the paper width guides correctly. Try printing a Configuration report to determine which paper size the printer is configured to. Any bits of paper stuck inside the printer roller might also cause paper feeding errors. Open the cartridge access door of your HP Officejet Pro printer. Wait for the ink cartridges to a position on the left. Look for any pieces of paper inside the cartridge area. If any bits are found, remove them. That should solve your problem. for more support Call our Toll-Free 1-866-293-9220 or visit
https://goo.gl/Pkv63e
How to Setup 123 HP OFFICEJET 3830 Printer
How to Setup 123 HP OFFICEJET 3830 PrinterUn pack the 123.hp.com/oj3830 printer from its packaging and keep the power cords ready to connect in its respective places. Now, place the cords firmly into the wall sockets so that there are no loose connections or any power issues with the devices. After connecting the cords, press the Home button on the left-hand corner of the printer.nice the basic setup is complete, install the printer software by visiting 123.hp.com or by inserting the CD which came with the printer. Follow the instructions on the screen to complete the printer installation process. Download the driver software from the website link 123.hp.com/oj3830 or 123.hp.com/setup 3830.
