20 Most Recent
Ariens MaxZoom60 60" 25HP Kohler Zero Turn Lawn Mower 2012 Model Questions & Answers
Ariens Zoom 40 Zero-Turn Mower won't drive
https://lawnmodel.com/ariens-riding-mower-transmission-problems-fixes/#:~:text=A%20worn-out%20or%20broken%20drive%20belt%20will%20also,when%20the%20mower%20is%20running.%20Defective%20pressure%20switch
Mt ariens Ezra 1742 won't spark and start
Check the start relay (not starter solenoid) energizes during crank. If the start relay does not energize then the magneto kill shunt is closed, hence no spark.
Comment for further assistance.
Model 915017 1542 zero-turn mower. How can I remove a deck pulley spindle?
See parts diagram
https://www.ariens.com/en-us/partsdiagrams?aribrand=ARN#/Ariens/915017_(000101_-_)_EZR_1542%2c_15hp_B%26S%2c_42%22_Deck/42%22_Mower_Spindle/6415040015/07200057/y
Likely you will need to remove the deck from the mower.
Then remove the blade, tray, and retainer to expose the woodruff key. Remove key and spindle should slide out of the spindle housing.
