20 Most Recent
HP Color LaserJet CM6040f MFP Q3939A Printer Questions & Answers
Hp cm 6040f half tone calibration error
Reset the NVRAM, HP support and google the procedure.Also, may be physical defect from the printer:
- ITB
- Fuser
- All cartridges
The only other parts involved with imaging would be the laser itself, or some kind of power problem where the laser isnt getting charged enough. You could try plugging it into a different wall outlet without a surge protector to confirm power source problems.
The imaging drums should all be included in the toner cartridges. They should have been ruled out when you swapped them before, its also unlikely all 4 drums would go bad at the same time.
Also, are you using refills or OEM cartridges? It shouldn't matter but refills/refurbs can have some strange defects. If you have a spare teh same model of printer lying around you could swap the cartridges out from a working machine and see if the problem travels with the cartridges or not.
Regards, Mike
7/28/2021 6:22:26 AM •
HP Color...
Answered
on Jul 28, 2021
Initializing scanner hp cm6040
Most common cause of the error on this printer is the memory on the CPB (copy processing board) is bad. This board is picky about memory and typically only works with the actual HP memory designed for it. The easiest fix is to use the memory that is currently installed on the formatter, which is identical, and purchase 3rd party memory for the formatter, which will support any compatible memory.
5/19/2016 3:59:17 AM •
HP Color...
Answered
on May 19, 2016
What does 30.01.41 error indicate?
The copy processing board has an issue. This board is located on the back of the scanner. Check all the cabling if it is good then the board has likely failed.
11/28/2015 4:38:49 AM •
HP Color...
Answered
on Nov 28, 2015
Cm6040 unlock menu
Navigate the Administration menu
From the Home screen, touch Administration to open the menu structure. You might need to scroll to
the bottom of the Home screen to see this feature.
The Administration menu has several sub-menus, which are listed on the left side of the screen. Touch
the name of a menu to expand the structure. A plus sign (+) next to a menu name means that it contains
sub-menus. Continue opening the structure until you reach the option that you want to configure. To
return to the previous level, touch Back.
To exit the Administration menu, touch the Home button in the upper-left corner of the screen.
The device has built-in Help that explains each of the features that are available through the menus.
Help is available for many menus on the right-hand side of the touchscreen. Or, to open the global Help
system, touch the Help button in the upper-right corner of the screen.
The tables in the sections that follow indicate the overall structure of each menu under the Administration
menu
8/14/2014 1:09:12 AM •
HP Color...
Answered
on Aug 14, 2014
49ff09 error code
49.XXXXX ERROR To continue turn offthen onA critical firmware error occurred. Remove third-party products. Turn theproduct off and then on.
7/9/2014 5:26:36 AM •
HP Color...
Answered
on Jul 09, 2014
Error 13.20.00
That is a Paper Eject Jam.
The paper stopped at either the loop sensor (E), the fuser-output sensor (F) or the switchback sensor (G).
E & F are just prior to the paper going into the duplexer. G is a sensor in the duplexer assembly. If the sensors check out ok in diagnostics, then I would suspect worn feed rollers causing a paper late condition.
6/6/2014 3:03:38 AM •
HP Color...
Answered
on Jun 06, 2014
Rooler kit error
1 Turn the printer off.
2 While pressing [- Item] and [- Value] turn the printer on.
RESET MAINTENANCE COUNT appears, followed by INITIALIZING.
After a few seconds READY appears.Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
4/1/2014 10:47:20 PM •
HP Color...
Answered
on Apr 01, 2014
