20 Most Recent HP Deskjet F4140 All-In-One InkJet Printer Questions & Answers
The ink guage on my HP quit also but I was able to access via the tool box. Not sure if this is a software issue or the touch screen. You might be able to access the ink level when you go to print and do advanced settings. The ink level may be presented depending on your print program.
HP Deskjet F4140... | Answered on Oct 06, 2014
a printer should be airprint enabled ideally, this will let you print from ipad etc, there is a list on the apple site: http://support.apple.com/kb/ht4356
or you could try various apps, one popular one is print n share
hope this healps :)))
HP Deskjet F4140... | Answered on Jan 03, 2014
check your printer
1. do it have power.... power on an then power off see if this step resolve your problem
2. latest printer driver (update)
3. ipad + canon in same wi-fi network
4. enough paper
everything ok?
  1. Tap ht4356--alt--en.png or ht4356----en.pngbottom of your screen.
  3. Choose your printer, the number of copies you want, and then tap Print.
HP Deskjet F4140... | Answered on Jan 01, 2014
The printer must be ON. Open the Front Access Door of the Printer. You should see a Carriage ( the part that holds the cartridges ) move from left to right. Wait for the Carriage to Stop ( usually in center ).
Open the packaging tape from the cartridge and slide the cartridge inside the Cartridge slot. Insert the cartridge from below and Push the cartridge upwards to snap. You will hear the snap sound.
Close the front access door and wait for the Cartridges to be aligned. After the printer has printed alignment sheet, Place it face down on the Scanner glass and press OK button.
The alignment will be complete.
Regards,Suhail
HP Deskjet F4140... | Answered on Dec 02, 2011
Hi Josh,
Try disconnecting the usb connections to the PC.
Uninstall the printers software and reboot your computer.
Turn off the printer and then on again.
Insert the installations disk into your computer.Follow the installation instructions and connect the printer only when prompted by the installation setup to do so.
Hope this helps.Thanks!
HP Deskjet F4140... | Answered on Nov 15, 2011
Change the Options on your HP Scanning Software to Scan in Colour or Else:
In this case u have to scan and Preview the scanned images using Windows Photo Gallery.....
Click on File and Click on Import from scanner or Camera...........
Then again click on Import...........It will scan and preview the Applications to u....
Thanku.......
Good Luck!@@!
HP Deskjet F4140... | Answered on Sep 23, 2011
Go to start, control panel, printers and right mouse click the printer. Click the setting.
HP Deskjet F4140... | Answered on Sep 10, 2011
The first thing that you must do is make sure that the device is already installed to your computer. Insert the document to be scanned on the scanner. Double click the icon of your scanner and on the option menu click scan. After the scanning process, open the My Picture folder of your computer and locate the image file.
HP Deskjet F4140... | Answered on Sep 02, 2011
Your printer is only capable of the following speeds.
Black Print Speed Up To 20 ppm Color Print Speed Up To 14 ppm
This does not take into consideration the size of the file you are sending to the printer which also takes time to spool. Always remember you get what you pay for and this is a cheap low end printer.
HP Deskjet F4140... | Answered on Aug 30, 2011
Go to this link to download the software
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=3235310
You will have to select your operating system. On the next page, you should see a + sign beside Driver - Product Installation Software. Click it and select the software to install your printer.
Hope that helps!
HP Deskjet F4140... | Answered on Aug 26, 2011
is it giving any error while giving print command? goto start settings printer & faxes open the printer icon by double click .any job is pending in the queue? try remove the usb cable and check t below the pinter icon whether it shows off line?
HP Deskjet F4140... | Answered on Aug 04, 2011
HP Deskjet F4140 All-In-One InkJet Printer Logo
91 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
hp deskjet f4140 wont scan button just
  • Office Equipment & Supplies
