20 Most Recent
Canon PIXMA MP600R All-In-One InkJet Printer Questions & Answers
Mp600r keeps saying offline
Go to start menu, usually in bottom left corner. Go to control panel, find printers, double click. Find your printer (you should see the name of your printer. If you do not see it there, it is not installed. If you do see it right click on the icon, and left click set as default printer. You should see a green check mark by your printer icon now. If not try again. If that fails, uninstall and reinstall your printer software, following your manufactures instructions.Hope this helps
MP600 R eror message :
may be the door sensor / switch not pushing properly. , check the switch, and the connector for the same
Getting error code on printer screen A600 why does
Mine kept doing that. My dad found website where lots of people had turned it upside down, shook it and then was fixed, so we tried it and it actually worked!! Now is printing again and no error codes!! Worth a try!!
When printing colour its printing
This may be your color cartridge is dry or make sure you not giving print in grayscale mode.
make sure your both the cartridges are working properly and it is not dry just remove the color cartridge and clean it with tissue paper and fix it again and when you give print command make sure it is not in grayscale printing. If still there is problem change the color cartridge.
Have a nice day and do not forget to rate please...!
Wrong language displayed on canon mp600
1) With the printer power on, press the "Home" button - (looks like a house)
2) Use the scroll wheel or the keys to select the "Settings" icon - (looks like a pair of pliers and a screwdriver), Press <OK>
3) Use the scroll wheel or the keys to select the "Device Settings" icon - (looks like two horizontal sliders), Press <OK>
4) Press the "Down" key four (4) times, Press <OK>
5) Use scroll wheel or Up/Down keys to select "English," then Press <OK>
Paper Jam
I would get a can of compressed air and completely spray out the printer. Most likely there is a bit of torn paper somewhere that needs to be pulled out.
Or unplug the printer completely and let the power completely dissipate and then plug it back in.
Let me know if you have any further problems.
Poor Wireless Printer Connection
Yes move the printer closer to the router or vice-versa, or make sure their are no microwaves between the router and printer. Chordless phones, thick mason or plaster walls can also hurt the signal range...Good Luck
