20 Most Recent HP Laserjet P4515x Printer Questions & Answers
The black lever where the paper comes out (right side) is stuck down, lift up to unstick.
this is temp. will stick again unless you clean it.
remove 4 screws undo the white lever that is attached to door
(right side)
lift up top
put upside down
look at black lever
there is a pad that has melted and is sticky
clean ( remove is best with flat screw driver) then clean
put back together.
solved
HP Laserjet... | Answered on Jan 06, 2017
Press "Menu"
Scroll to "IO sub menu" Enter
Scroll to "TCP/IP" Enter
Scroll to "Manual settings" Enter
You can see the saved IP address, it can be change, enter desire IP address...enter for save the changes....back to main menu..
To confirm: (You can follow the above said method to see the saved IP) OR
Press "Menu"
Scroll to "Information menu" Enter
Scroll to "Print menu map" Enter
Printer prints menu map, you cam see the entered IP address here, if you found its success, if not try once again..
HP Laserjet... | Answered on May 12, 2014
Reset the maintenance-kit counter
1. Turn the product power off and then on.
2. When XXX MB appears on the control-panel display, press and hold down the OK button until all three control-panel lights flash once, and then stay on. This might take up to 10 seconds.
3. Release the OK button and press the up arrow to scroll to NEW MAINTENANCE KIT.
4. Press OK to reset the maintenance-kit counter.
HP Laserjet... | Answered on May 25, 2013
This is the HP solution for the problem
HP LaserJet, Color LaserJet and LaserJet MFP Products - Print driver Client / Server Connections in a mixed 32-bit and 64-bit environment ISSUE: 32-bit clients are not able to connect to shared Universal Print drivers or discrete drivers on a 64-bit print server or vice-versa. These scenarios may involve Server 2003/Server 2008 64-bit print servers with Windows XP, Vista, 7 32-bit clients. It is also possible that the server editions could be 32-bit versions with 64-bit clients. SOLUTION:
  1. The administrator will need to download the 64-bit AND 32-bt version of the print driver from www.hp.com . If the server involved is a 64-bit version, the 64-bit version of the print driver will need to be installed and mapped to the printer via TCP/IP. Ensure that the print driver has been shared on the network by going to the print driver properties and enabling Share this printer within the Sharing tab. c02030528.gif
    Ensure that communication has been established and that a driver test page can be printed from the 64-bit server. Once functionality has been confirmed from the 64-bit server, proceed to the next step.
  2. Currently, 64-bit clients will be able to connect to the shared 64-bit print driver that has been installed on the 64-bit server as the architecture currently matches. However, if 32-bit clients wish to map to the shared 64-bit print driver on the 64-bit server, the 32-bit version of the same driver will need to be installed within the current 64-bit driver.
    This process can be done by navigating to the printer properties of the 64-bit driver on the 64-bit server, clicking the Sharing tab and clicking the Additional Drivers button. c02030529.gif
  3. Once the administrator clicks on the Additional Drivers button, the next screen will allow the administrator to load the 32-bit drivers by placing a checkmark in the x86 button and clicking the OK button. c02030530.gif
  4. Once the administrator clicks the OK button, a print driver window will pop-up asking for the 32-bit driver components. Again, the administrator will need to download, and extract the 32-bit version of the print driver on the 64-bit server. Once the window below comes up, the administrator will need to navigate to the 32-bit driver components and select the appropriate driver .inf file.
    For example, the UPD .inf file would be the first file in the list and be named hpcuXXXc.inf. c02030531.gif
    Once the appropriate .inf file is selected, the 32-bit driver components will be installed within the 64-bit driver on the 64-bit server. This can be verified as both x86 (32-Bit) and x64 (64-Bit) boxes will now be checked and show the status as installed by clicking the Additional Drivers button compared to the screenshot in Step 3 above.
  5. Now that 64-Bit and 32-Bit drivers have been loaded onto the 64-Bit server, 32-Bit and 64-Bit clients can now navigate to the shared print driver on the 64-Bit server, by manually navigating to the shared print driver on the 64-Bit server from the client machine. Typically the path is \\servername\sharedprintername.
  6. Once the client maps to the shared print driver, printing should work successfully.
    For problems or errors that continue to occur after completing the aforementioned process, ensure that the latest version of the print drivers are being used www.hp.com . If there are problems with older discrete drivers, it is recommended to use the latest version of the Universal Print Driver which can be found at www.hp.com/go/upd .
HP Laserjet... | Answered on Mar 30, 2011
Pull out the powercable and leave it out for several minutes. Then plug it back in. See if somthing happens now.
HP Laserjet... | Answered on Mar 11, 2011
thisis the farmetter problem
HP LaserJet... | Answered on Nov 11, 2019
Juliet. Most likely the scanner lamp, or scanner control unit assembly is defective. If you're technically savvy, you could remove the scan glass and lube the shaft that the scan lamp assy slides on. Sometimes that will fix it. Otherwise, the whole top scan unit will need replacing. That could cost over $300 for the replacement.
HP LaserJet... | Answered on Oct 07, 2019
I have face a problem in laserjet m1136 i.e. show a e8 error .how can i free it or remove it..
HP LaserJet... | Answered on Oct 03, 2019
bad toner cartridge. Probably black
HP LaserJet... | Answered on Aug 28, 2019
To select the default language on the Control Panel:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Control Panel Setup], and then press the [OK] button.
More items...
SOLVED: Change language from german to english on p3015 - Fixya
www.fixya.com/support/t12816917-change_language_from_german_english
change the language on HP laserjet 3015 printer Google Search
HP LaserJet... | Answered on Jul 16, 2019
Guys, its easy.. I found a little piece of paper after seeking calmly. It was on the paper pulling system when collecting from the tray. See the pic, it was right whee i'm pointing with my tool. It was locking one of the sensors around there. See in the third image where my tool is pointing.. Its exactly inside and very difficult to see.. And one more thing.. You'll have to unscrew the upper cover to see it.. Good luck
I love smart gadgets like this. Easy to solve. 1d69ed0c-5731-4c6b-ae7c-d49ff90e96d8.jpg 8e1e42b8-3851-411a-98e1-09eb08d019b9.jpg dd6af869-4bf3-4193-af33-57d2d362752b.jpg
HP LaserJet... | Answered on Jun 30, 2019
HP Laserjet P4515x Printer Logo
Popular Tags
20 questions posted
Ekse
Thomas F. Schneider
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
maintenance reset
  • Office Equipment & Supplies
