20 Most Recent eMachines W3506 PC Desktop Questions & Answers
Below are links to the eMachines driver download sites for your models:
W3506: http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1450
W3107: http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1443
T2682: http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1518
To find drivers for other models, simply click the "change selected product" link at the top of any of the above driver pages.
If you find this solution helpful, please leave a positive rating!
eMachines W3506... | Answered on Jun 20, 2011
This perticular model can handle up to 4GB of RAM. There are 2 DIMM slots on the motherboard the lay vertical about 4-5 inches long. Simply push the white plastic clips on each side of the chip and it will eject the chip out. Replace by reversing the process. And be sure to replace with proper RAM that is compatible with that board. Use SIW (free download) to find out which ram you have in it now.
eMachines W3506... | Answered on Apr 29, 2011
go to control panel from the start menu select performance and maintenance then select power options. then where it says stand by select how long after not being used you want the computer to stand by
eMachines W3506... | Answered on Jan 31, 2011
The only real way to testa power supply is to replace it with one known to be working and of a similar wattage, this will tell you if this is the problem.
eMachines W3506... | Answered on Jan 06, 2011
It sounds like a mechanical failure of the drive tray.
Use a un-bent paper clip and stick it in the tiny hole near the tray of the drive to attempt to prod the tray out of the drive.
Most likely there is something (a CD probably) stuck in the drive.
It may take a good deal of jiggling and bumping of the drive to get whatever is blocking it to come free. Be patient but firm.
eMachines W3506... | Answered on Dec 31, 2010
download and install cpu-z from www.download.com it should show you all the info.
eMachines W3506... | Answered on Oct 24, 2010
HI There,
Here is the link to the drivers and applications for your computer which also shows on the left that WIndows 7 is not supported. Sorry for the bad news so please don't thrash my rating with a negative feedback.
Thanks and best of luck.
http://www.emachines.com/support/drivers.html
eMachines W3506... | Answered on Sep 01, 2010
You need to try these solutions:check the power cord to see if it is connect to the computer and the wall outlet properly.You should try using another wall outlet,you should change the power cord if the problem still exist,another solution you should try is changing your power supply because it may be dead.
eMachines W3506... | Answered on Aug 17, 2010
yes a mid sized. and it is call mATX for the form factor.
-socket 775
-DDR2
-PCIE
-mATX
eMachines W3506... | Answered on Jun 05, 2010
Download a DVD, ISO file, from say a torrent site and burn to DVD. You may have to elicit a friends machine to do this. Or purchase a DVD. Also ensure you FIRST get & download ALL the drivers you need from the manufacturers web site.
eMachines W3506... | Answered on Feb 13, 2010
they should be attached to the pins on the motherboard as they are normally marked on where they go
the pins are on the edge nearest the bottom front of the pc
they normally look like this
just a case of matching them up to the wiring
if your not sure then go to motherboard manufactures website and download the manual from there.
eMachines W3506... | Answered on Aug 18, 2009
Error 680 meals no dail tone!,
1. is the phone cable modem plug into the modem port and the phone jack.
2. do you have a dial tone, when you pick up the receiver.
If you heard a dial tone, is it continuous?
3. are you using DSL Modem? or broadband connection?
If you have another cable available, try it. A bad cable could be the problem.
Next, check the modem. Is it turned on? When you try to dial out, are the lights blinking? If they’re not, the modem might be damaged. If it’s possible, attach another modem to see if that solves the problem.
eMachines W3506... | Answered on Jan 23, 2009
What's plugged into it?
eMachines W... | Answered on Mar 29, 2014
Your desktop computer does not have a wireless adapter.
eMachines W... | Answered on Mar 16, 2014
Looks promising. It's an INF fie which are driver files. Download, extract, and direct Device Manager where to install driver from. The worst that can happen is it won't install, or you have uninstall / delete. Better than those fake drivers you mentioned.
eMachines W... | Answered on Feb 18, 2013
Check cables, connections, pins, If you have a Graphics Card, reseat it. Sound like a connection or graphics issue. Do you have a can of Electronic's Contact Spray? I use it for cleaning connector, PCI slots, etc., Where copper connections oxidation occurs. May be a simple reset or bad Graphic Card. Hard to say for sure.
eMachines W... | Answered on Dec 17, 2012
Did you check W7 compatibility before install? It is likely that your low-end RAM-based graphics was a bust.
eMachines W... | Answered on Oct 27, 2012
eMachines W3506 PC Desktop Logo
Popular Tags
18 questions posted
Top eMachines Computers & Internet Experts
Thomas F. Schneider
Ekse
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
W eMachines
  • W eMachines
Most Popular Question
lite combo sohc 4836v dvd cd rw drive
  • Computers & Internet
