20 Most Recent eMachines etower 466id PC Desktop Questions & Answers
Installing power supply, need diagram to insure
Hi.
Normally you do not need a diagram to connect a computer power supply, since the connector will snap into the motherboard socket only in one possible way.
The connectors that you need to hook up are a 4 pin squared connector and the big 20 pins rectangular connector.
Here the 4 pin :4 pin MOLEX 39-29-9042 connector
Here the 20 Pins 20 pin MOLEX 39-29-9202 connector.
the 4 pin is located near to the CPU.
There is no way to connect the 20 pin connector wrong, and the 4 pin connector can be placed in the wrong way only pushing very hard to force it into the socket. One of its pins is different, so that it does not allow connecting the plug in the wrong way.
12/6/2009 6:15:36 PM • eMachines etower... • Answered on Dec 06, 2009
3answers
I'm trying to find what the cpu socket is so i can
You can't upgrade a CPU.
10/25/2009 3:04:56 AM • eMachines etower... • Answered on Oct 25, 2009
After etower shut down for some time it wil not start
It is possible that the power supply could be dead, I've seen this many times when people move their computers around.
3/25/2009 3:30:48 AM • eMachines etower... • Answered on Mar 25, 2009
I updated BIOs and now every thing is gone.
Okay, sounds like your BIOS upgrade went south. First off, re-install the original BIOS. Usually you back up the original before upgrading. Either that, or d/l the original BIOS from emachines.com. Once you've got the BIOS working, try starting the system. I'll need to know more to help you from there.
2/24/2009 8:52:40 AM • eMachines etower... • Answered on Feb 24, 2009
I counted 13 quick beeps at startup on an emachines E520. what dose that mean ? how do i fix it please ?
Thirteen quick beeps at startup on an eMachines E520 usually indicate a problem with the laptop's RAM (Random Access Memory). This could mean that the RAM is not properly seated in its slot, or it could be a sign of a faulty RAM module.
Here are some troubleshooting steps you can try to resolve this issue:
Turn off the laptop and disconnect it from the power source.
Remove the battery from the laptop.
Locate the RAM compartment on the bottom of the laptop.
Check to make sure that the RAM module is seated properly in its slot. You may need to remove and reinsert the RAM module to ensure a proper connection.
Replace the battery and turn on the laptop.
If the problem persists, try removing the RAM module and testing it in a different laptop or using a different RAM module in the eMachines E520 to determine if the problem is with the RAM module itself or with the laptop's RAM slot.
If none of these steps solve the problem, it may be necessary to contact a computer technician for further assistance..
3/22/2023 9:07:20 PM • eMachines... • Answered on Mar 22, 2023
How to factory reset a Emachines Etower 633id it boots up but says operating system not found it has Microsoft Windows ME Millennium Edititon (from Windows 2000 Professional)
  1. Boot the computer to the boot menu: To do this, restart the computer and press the appropriate key when prompted to enter the boot menu. On most eMachines computers, this is the "F12" key.
  2. Select the CD/DVD drive as the boot device: Use the arrow keys to select the CD/DVD drive and press the "Enter" key to boot from it.
  3. Insert the Windows ME boot disk: Insert the boot disk into the CD/DVD drive and restart the computer.
  4. Choose the "Start Computer with CD-ROM support" option: When prompted, choose the "Start Computer with CD-ROM support" option.
  5. Run the Windows ME setup program: The setup program should start automatically. Follow the on-screen instructions to install Windows ME.
  6. Format the hard drive: During the setup process, you will be prompted to format the hard drive. Choose the "Full" format option to erase all existing data and perform a complete factory reset.
  7. Install Windows ME: Continue to follow the on-screen instructions to complete the installation of Windows ME.
After the installation is complete, the computer should be in a factory reset state and you can begin setting it up as a new system. Please note that resetting your computer to the factory settings will erase all personal data and installed programs, so be sure to back up any important data before proceeding with the reset.
2/13/2023 2:51:11 AM • eMachines... • Answered on Feb 13, 2023
2answers
How do i remove the bios password i set but forgot. i want to change some settings and cant get through.
Larry picks up a question from 2015 ;>) Larry Ng Feb 07, 2022 no PC model told hopeless If desktop, the jumper on the MOBO marked PW_CLR on most. Never laptops
6/21/2022 8:55:19 PM • eMachines... • Answered on Jun 21, 2022
2answers
My local disk E is missing.
device manager 1 of 10000 model ODD optical disk drives made, each drive made has LIMITS some only do CD ROMS BD is blue ray , FIY if missing or maked with red or yellow errors or shows up as unknown that all means DRIVER IS BAD , wrong or missiong NO PC Told so can not tell you how to fix that, lacking such a key fact . (but is at your oem makers PC support page under DRIVERS) brd-undefined-undefined-0.jpg
6/21/2022 8:52:19 PM • eMachines... • Answered on Jun 21, 2022
Hi! I have an emachines laptop E525.I is not going on
moved you out of monitors and into laptops, only forum. emachines full model not old like this example E525-901G1Mi windows 7 loaded day1.
  • the switch is bad Lid close switch
  • set wrong in power settings.
  • or the driver is missing that makes this switch work.
so why not just assign the sleep mode, to auto sleep then on what does the power button do in settings, set to do nothing or set button to only sleep . (3 choices here) or let auto sleep do the work, set. set to say 5min idle. the switch is inside it deep and if you rip it out as you go there most noobs break 2 or 3 FFC cable jacks and now it is bricked and $300 mobo wrecked emachines or junk grade, made by Acer.com owned now and that maker does NOT have service manuals making service a royal Pain. best is work around the problem as I just told how. or ask any shop to fix it. they do know how.!!!
5/16/2022 1:18:24 PM • eMachines... • Answered on May 16, 2022
2answers
Reset my eMachines eM350-2074 Black Intel Atom N450(1.66GHz)
Larry has the answer. Larry Ng Feb 07, 2022 no reason stated, the OS reloaded, ?that? what does reset mean to you? and why.? (selling PC or PC infected?) what:"? ahhhh a Netbook sold new with XP or W7, lost the install media? page 22 in your manual shows that you must create recovery media day one, new. if not , it is GONE. https://www.emachines.com/ec/en/US/conte... ..
5/4/2022 2:12:26 PM • eMachines... • Answered on May 04, 2022
2answers
I can't get my emachines 525 to start up all i get is operating system wasn't found so what do i do
Check the hdd is setup correctly and set as first boot device. Ensure there is no external drive/usb installed.
4/7/2022 6:31:04 PM • eMachines... • Answered on Apr 07, 2022
2answers
I have a eMachines 525 when I start it up all I get is operating system not found
e525 lapTOP OR? FOR GOT TO TYPE THE "e"????? 2009 MADE? 13 YEARS AGO? 2 causes (of many but 2 are CLASSIC COIN cell is now dead CMOS and boot order lost. or hdd bad the cure is, new coin, and reset bios and set boot order to hdd0 first the hdd must pass smart tests. or all hope is gone foR IT. ask how. that error means boot order wrong or hdd is bad. boot fails missing on hdd is bad HDD 99% the time. NO COIN LASTED 13 YEARS. AND MOST HDD SAME THING. UNLESS PUT IN TIME CAPSULE IN Ln2, CRYRO FREEZED. now the BAD NEWS the COIN cell is soldered down to the MOBO and is not a normal CR2032 it is ML1220 rechargeable listed as 5 year life.(MAKER OF COIN) so you fOUND this PC in a garage sale dead for $1?>???? no history told at all, ever fix old cars. ? emaciates now owned by Acer and Toshiba does this nasty trick "solder down" e525 actual 525-undefined-undefined-0.jpg there it is, in all its glory, lots of screws to get and soldering pen to release it, I cut the wires up top and solder then new coin to top wires. and not touch mobo PADS that is a huge hint there.(do no harm)
4/7/2022 6:30:31 PM • eMachines... • Answered on Apr 07, 2022
REPLACE EMACHINE E644G 0663 WITH A NEW SEAGATE HARD DRIVE
how to do this physically or just putting back a new OS there. or what to buy it. or what what parts are unclear.
  • buy new,hdd, or 100x better SSD
  • install it.
  • install what ever OS you want. w7 -64bit new.
age 2011,
2/7/2022 10:26:39 PM • eMachines... • Answered on Feb 07, 2022
My emachines laptop takes quite a long time to start up. when I press the power button on, the power button turns on but the screen remains black until after 1 hour or more. what could be the problem?
classic case most old PC on earth slow. No PC told at all the model, wow.
  1. hdd full
  2. OS virus infected. N
  3. HDD bad, fails smart test.
  4. memory full, add more or git ride of autoloading apps,
2/7/2022 10:22:38 PM • eMachines... • Answered on Feb 07, 2022
How do I remove the hard drive from my EMachine tower
No PC model told. desktop (vast there are) same on all desktops made one side of case. remove 2 cable to drive remove 4 side screws from side of drive to cage. remove drive, slides out. some PCs the drives have caddies. no PC told the manual is here https://www.emachines.com/ec/en/US/content/support.html
2/7/2022 10:20:10 PM • eMachines... • Answered on Feb 07, 2022
I need the bios password on the emachines625. can you help?
625 means what? e625? note book? forgot the "E"" ASK THEM,? YET. https://www.emachines.com/ec/en/US/content/support.html
2/7/2022 10:17:44 PM • eMachines... • Answered on Feb 07, 2022
Intel rst service is not running
eMachines eME528-2325 Specificationsyou left off 1/2 the real model #Mobile IntelĀ® GL40 Express Chipset , A LAPTOP PCNO OS told, w7 new it had (still)?, well that needs a driver to work AND DOES NOT WORK ON NEWER OS NOT TOLD..THE MAKER OF THIS LAPTOP HAS GL40 DRIVER THAT USES NONE RAID MODE, (laptops can not use raid, no space for 2+ hdd) that means only gl40 drivers work;.here they all arehttps://www.emachines.com/ec/en/US/content/drivers.html11 drivers there for one PC (this one) per OS.w7the 2 marked Intel must be loadedbest is first turn off RST mode in BIOS (no raid)and set ACHI only . there.RST is RAID and not used.pitfalls (no OS told at all guess nasty XP/VISTA.)the coin cell is dead, and if is, cannot be ignoredthe bios reset on bios page 1.RTS (intel raid chip) disabled in Biosall sata ports turned on.in bios.set SATA to ACHI mode, for modern windows. in bios.a good HDD that passes smart tests.boot order set to hdd0- first. in bios.keyfacts, Intel ended all support for the old RST chip and must be disabled now for all newer OS.some RST drivers see bios RAID off and load in ACHI mode automatically or not.saveexit bios, cold boot it to USB windows install mediaand load the secret OS now.fresh, (I erase all HDD that had virus first )_
2/7/2022 10:07:19 PM • eMachines... • Answered on Feb 07, 2022
How do i installed whattsup on my emachine laptop
to go whatsAPP.comget it.https://www.whatsapp.com/app not up.
2/7/2022 10:03:23 PM • eMachines... • Answered on Feb 07, 2022
Trying to open my emachines DVD/CD drive that is stuck shut
well lay the PC on its side do disk is up. not shake it a see is eject button works most driver, have the hail Mary pin hole there for the paper clip eject tub some of these confounding vertcles have non so must now be dismantled. NO PC told at all, model , one one clue. must be think cased mini desktops, infamous for that. EL1200? the other kind is there is no tray like my Sony PS3. it a grab out of the hand ODD, if kids put 2 disks in side it is now jammed. and must be dismantled, el1200 has front trap door, that drops down and the see a Laptop classic drive and the PIN hole see that./ NO PC told so crazy long answers all 3 technologies told.
1/22/2022 8:21:37 PM • eMachines... • Answered on Jan 22, 2022
Emachines eM250 KAV60 reset bios password
  1. did you forget it
  2. or bought it used like that?
  3. or just out of the blue BAM silly PW needed, :???????
Laptops are very hard to fix like this, no PW clear jumpers 2009 made, the coin cell battery is dead, on that day #3 above and not BIOS lies to you. understand the gravity of that? it must be replaced and if lucky no more PW.
1/22/2022 8:21:24 PM • eMachines... • Answered on Jan 22, 2022
eMachines etower 466id PC Desktop Logo
Popular Tags
6 questions posted
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • eMachines Computers & Internet
Most Popular Question
trying find cpu socket
  • Computers & Internet
