20 Most Recent eMachines T3516 PC Desktop Questions & Answers
IT goes and connect to motherboard :)
eMachines T3516... | Answered on Aug 15, 2012
This is an itchy problem. Try installing a program called Calamine.
Reload latest audio drivers for your system.
eMachines T3516... | Answered on May 12, 2012
the drivers might be installed properly for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
hope this helps you
eMachines T3516... | Answered on Oct 24, 2011
This should solve your problem:
1. Start the Recovery Console. If you do not have the Recovery Console installed, start it from the Windows XP compact disc (CD). To do this, follow these steps:
a. Insert the Windows XP CD and restart the computer. If prompted, select any options required to boot from the CD.
b. When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
c. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the recovery console.
d. When prompted, type the Administrator password.
2. At the command prompt, type "cd \" (without the quotation marks), and then press ENTER.
3. Type "ren ntldr ntldr.old" (without the quotation marks), and then press ENTER.
4. Type "map" (without the quotation marks), and then press ENTER.
5. Note the drive letter assigned to the CD-ROM drive that contains the Windows XP CD. It is displayed in a format similar to the following: D: \Device\CdRom0
6. Type "expand <drive>\i386\ntldr._" (without the quotation marks) (where <drive> is the drive letter of the CD-ROM drive that contains the Windows XP CD), and then press ENTER. For example:
Expand d:\i386\ntldr._ <ENTER>
Note the underscore character after the "."
The following message appears: ntldr, 1 file(s) expanded.
7. Type "exit" (without the quotation marks). The computer restarts.
8. Remove the Windows XP CD and start the computer normally.
IF that fails put in your Windows installation CD and reinstall the operating system
eMachines T3516... | Answered on Oct 14, 2011
Assuming that the driver in question is a LAN driver (for your high speed Ethernet port), then this would be the proper driver(s) for your machine:
http://support.gateway.com/us/en/emac/product/default.aspx?modelId=1574
choose LAN driver.
If this is a dialup internet connection, then you would have to get a driver from your modem manufacturer.
eMachines T3516... | Answered on Jun 24, 2011
Go to www.emachines.com , select customer care, click on desktops, scroll down to drivers and downloads, enter your product information and operating system and download your drivers. Have Fun!
eMachines T3516... | Answered on Oct 13, 2010
No, if the computer will start and it run bios screen and boots into windows
the cpu is fine, you need to get a better cpu cooler.
Buy a better cpu cooler for your socket, coolers are designed for the Socket that the processor plugs into.
Go to Newegg.com and llok for a cooler, you will see reviews by people
and if they liked the cooler, there are little eggs next to the product
is it has high ratings, you will see what I mean when you look at the site.
The page I posted is already on the cooler page, just llok to the left side
and look at sockets and pick your socket out to look at coolers for your system.
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=574&name=CPU-Fans-Heatsinks
eMachines T3516... | Answered on Feb 07, 2010
A direct3d device is a 3d video card. Get one from your local hardware supplier.
eMachines T3516... | Answered on Nov 18, 2009
I do not believe emachines computers come with restore disks. You will need to contact the place you purchased your computer to see if they can get you one, or you will need to buy a windows disk to reinstall. You can download all the drivers for your computer from emachines.com.
http://emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T3516
Click on downloads to see the drivers for your computer!
eMachines T3516... | Answered on Jun 28, 2009
if you have the disc that come with your computer get the drivers from there.
eMachines T... | Answered on Nov 18, 2016
Guessing, but it sounds like your hard drive has been damaged. You may need a new drive, or at least repairs. If you have a "rescue disk", give that a try.
eMachines T... | Answered on Sep 05, 2015
Here's a video on how I fixed my emachines boot problem. Almost anything can get in the way of your computer booting. Software, hard drive, RAM, motherboard, processor, etc. Below the video, I attached a link to a tip I made about computer crashes. Computer Crashes and Electrolytic Capacitors
eMachines T... | Answered on Jul 01, 2015
Please specify how exactly you're trying to make them work, what machine you're trying to make them work with, and what kind of connection your speakers are using.
General info:
Speakers usually get connected via 3,5 mm plug into the green round socket in the back or front of your computer. In Windows, if your speakers are properly connected and set up, right click on the sound pictogram in your taskbar and choose "Playback devices". Set your speakers to be the default playback device by left-clicking on the preferred device of your choise and clicking the button "Set default" below.
eMachines T... | Answered on Aug 04, 2014
In general, you have to order recovery disks from the manufacturer of the machine.
In your case eMachines Store eRecovery is where you can order it, or you can initiate a discussion with tech support.
Also, many machines give you the option to burn your own recovery media when you first set it up. Most people skip this step. You should do this before you have problems. Search your machine for the word Recovery and see if you have an installer routine there.
Here are instructions to create a recovery disk on a USB stick
Create USB recovery drive Windows Help
eMachines T... | Answered on Jul 30, 2014
Check your monitor cable connections. If not solved, try a different monitor.
eMachines T... | Answered on May 08, 2014
Flashing the bios is a last-ditch move. What happened before that?
Did it work before you flashed it? If the unit is interrupted during clash, or if it is the wrong bios, your goose could be cooked.
Read this:
http://www.techpowerup.com/forums/threads/flashed-wrong-bios.180492/
There may be something you can use, especially if you have a floppy drive (a real one, not a usb-one).
You maybe can use flash drive in the usb port, but that's a long shot.
Good luck with that. I'd be looking at a new motherboard. They can be had pretty cheaply.
eMachines T... | Answered on Dec 17, 2013
I understand that you want to reinstall the Operating System on the computer. Select models have the ability to have the operating system reinstalled from a hidden drive built into the computer. To start the system recovery:
  1. Restart the computer
  2. When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. When prompted with a boot screen, hit the Enter key.
  4. After the system recovery program has loaded, follow the prompts to reinstall the operating system.
If the ability to reinstall from the previous method is not available or fails during the recovery, recovery of the operating system will need to be from Recovery Media.
  1. Insert the disk labeled System CD into the computer's disk drive and restart the computer.
  2. When the eMachines logo appears on the screen, press the F12 key repeatedly.
  3. Select either CDROM or DVD as the boot device, this may vary depending on the system.
  4. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
  5. Note: If there are multiple Recovery CDs, please insert the first Recovery CD.
  6. After the system recovery program has loaded follow the prompts to reinstall the operating system.
Refer the URL for more information and for the link to order the Recovery media if required.
eMachines T... | Answered on Nov 19, 2013
eMachines T3516 PC Desktop Logo
Popular Tags
20 questions posted
Top eMachines Computers & Internet Experts
Thomas F. Schneider
Ekse
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
T eMachines
  • T eMachines
Most Popular Question
im unsure install updated drivers
  • Computers & Internet
