20 Most Recent eMachines W3653 Refurbished Desktop Computer - Intel Celeron Dual Core E1200 1.6GHz, 1GB DDR2, 320GB Questions & Answers
0answers
Why wont it power up
A) It's lazyB) Too tiredC) It's TuesdayD) The ATX Power On switch is bad, or the Power Supply.Suggest you diagnose by bypassing the Power On switch.Has nothing to do with the Power On switch, or it's wires. A jumper wire is used on the Soft Power On wire to ANY Ground wire.The eMachines W3653 Desktop PC uses an ECS 945GCT-M3 motherboard,http://support.gateway.com/s/MOTHERBD/Shared/4006188R/4006188Rnv.shtmlUses a 24-pin ATX main power cable,http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24[Note* Color of connectors does not matter ]Note the Green wire going into the back of the power cable's connector. This is the Soft Power On wire. (Abbreviated PS_ON)Note all the Black wires. ALL Black wires are Ground wires.The preferred jumper wire is a straightened out paper clip, then bent into a U-shape.The top of the U is wrapped a few times with black plastic electrical tape. This taped area is for your fingers and thumb to hold onto.Turn the U-shaped jumper wire upside down, and the 'legs' are what is used.One leg goes down into a socket hole with the Green wire.The wires go down into the Back of the power cable's connector.Down into socket holes in the connector.The jumper wire 'leg' goes down into the back of the connector, RIGHT NEXT TO the Green wire, and slides down in the socket hole past the insulation of the wire.The jumper wire MUST go down far enough in the socket hole, to touch the metal terminal.Every wire going into the 24-pin ATX main power cable's connector, ends in a metal terminal,http://www.molex.com/molex/products/datasheet.jsp?part=active/0002081202_CRIMP_TERMINALS.xml&channel=Products&Lang=en-USThe other 'leg' of the jumper wire goes down into the back of the power cable connector, and into ANY socket hole that has a Black wire in it. ALL Black wires are Ground wires.The contact made is no more than 2 seconds.The Power On switch is Momentary Contact Switch.IF the Power Supply comes on you have a bad $5 Power On switch.IF the Power Supply does Not come on you have a bad Power Supply.http://www.directron.com/atxswitch.htmlFor additional questions please post in a Comment.Regards,joecoolvette
10/1/2012 6:08:35 PM • eMachines W3653... • Answered on Oct 01, 2012
I have a Emachines W3650, starts for a second,Makes one long beep
First you can get more information from the POST beep. (Power-on self-test (POST)). Using another PC from a friend or work search for this list on line. If you get one long beep there is an issue with the main board. Try taking out the memory and reseating each card. Also make sure the power connections to the mother board are good and tight.
8/20/2012 1:20:47 AM • eMachines W3653... • Answered on Aug 20, 2012
I try to login and enter my correct password and
Could be the User Account is damaged. Can u click F8 on startup and sign on as administrator? If so, go into control panel and into users and create a new user then restart the computer and sign into this new account.
Then you should be able to go into you C drive and retrieve the documents from the damaged user account.
Let me know if I can be of any more help.
1/22/2010 12:55:08 PM • eMachines W3653... • Answered on Jan 22, 2010
Windows media player keeps asking to connect a
Make sure in the windows media player options you have selected the corect drive as your burner. hope this helps in some way
12/4/2009 6:32:23 PM • eMachines W3653... • Answered on Dec 04, 2009
How to remove panel (back or front) from W3503 emachine
The manual is at... http://www.manualslib.com/manual/46776/Emachines-13.html?page=4&term=panel&selected=0 See page 46 "Removing the side panel".
5/18/2014 1:11:19 AM • eMachines W... • Answered on May 18, 2014
What is the emachine w 3502 amd chipsets?
What's plugged into it?
3/29/2014 4:51:01 AM • eMachines W... • Answered on Mar 29, 2014
My emachines t5212 will not find a wifi hotspot
Your desktop computer does not have a wireless adapter.
3/16/2014 8:41:39 AM • eMachines W... • Answered on Mar 16, 2014
2answers
W3502 emachine SM Bus Controller driver
Looks promising. It's an INF fie which are driver files. Download, extract, and direct Device Manager where to install driver from. The worst that can happen is it won't install, or you have uninstall / delete. Better than those fake drivers you mentioned.
2/18/2013 1:31:48 AM • eMachines W... • Answered on Feb 18, 2013
Emachine 1641-02w the monitor will not lite up the monitor is good because tried it on another computer
Check cables, connections, pins, If you have a Graphics Card, reseat it. Sound like a connection or graphics issue. Do you have a can of Electronic's Contact Spray? I use it for cleaning connector, PCI slots, etc., Where copper connections oxidation occurs. May be a simple reset or bad Graphic Card. Hard to say for sure.
12/17/2012 8:16:15 AM • eMachines W... • Answered on Dec 17, 2012
E machines w 3623 wont boot windows 7 fresh install
Did you check W7 compatibility before install? It is likely that your low-end RAM-based graphics was a bust.
10/27/2012 3:18:51 PM • eMachines W... • Answered on Oct 27, 2012
How Do I download
10/14/2012 3:09:59 AM • eMachines W... • Answered on Oct 14, 2012
I can't get emachines internet. how can i do it?
1) you must sure the Internet is working o.k 2) see if the modem LEDS are working good3) if you have Router see if the router is working with the LEDS, and see you have another computer connect and see if working.4) if additional computer is working the problem will be your computer PC.5) try to restore to some point when was working before.6) see if this work, otherwise you must download the driver for NIC NETWORk , BIOS+CHIPSET go to the supplier web and download.God bless you
9/28/2012 12:57:51 PM • eMachines W... • Answered on Sep 28, 2012
I restored my emachines computer back to factory setting using the disk that came with it and now when I try to download a CD it says
i assumed your os is window xp....try this steps;1. right click on my computer, left click on the properties2. select the advanced tab, under performance click settings3. on the advanced tab, under virtual memory click change4. Under Drive [Volume Label], click the drive you want to change5. Under paging file size for selected drive, select the custom size6. type 384 in the initial size (mb) text box7. click set and then ok 8. close the dialog and restart i hope this help.
6/14/2012 3:53:54 AM • eMachines W... • Answered on Jun 14, 2012
Internet Exployer keeps crashing & I don't know what else to do.
We had a problem like this with one of our PCs and it was a very nasty virus that needed specialist help, they had to reload all the software. Suggest you get access to another PC and find out if it is a virus. Sorry!
5/19/2012 1:26:48 PM • eMachines W... • Answered on May 19, 2012
Computer will not come on after shutdown. may take 12 15 hour
I would look inside at the power supply IF you can get to that for puffed up caps---if found you can either replace them (seen some with several bad) or look for a generic replacement power supply.4_16_2012_3_51_52_pm.jpgUsually here it will begin by being hard to turn on at first but once on will operate--sooner or later it will not come on at all.
4/16/2012 3:52:39 PM • eMachines W... • Answered on Apr 16, 2012
I need a W2040 motherboard wiring diagram
must be easier to move the hd to a hd-caseing and start transfer to a another computer......to much time-consuming.
3/27/2012 6:15:18 PM • eMachines W... • Answered on Mar 27, 2012
Emachines T5274a desktop computer have wifi
Most desktops do Not have wifi built in and specs for this unit do no show wifi , you usualy need to add a wifi dongle in a usb port or add a card.
2/17/2012 9:12:46 PM • eMachines W... • Answered on Feb 17, 2012
The DVD player on my computer does not work
then the dvd player needs to be replaced with a new one
1/17/2012 7:59:24 PM • eMachines W... • Answered on Jan 17, 2012
eMachines W3653 Refurbished Desktop Computer - Intel Celeron Dual Core E1200 1.6GHz, 1GB DDR2, 320GB  Logo
5 questions posted
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
W eMachines
  • W eMachines
Most Popular Question
emachines w3650 starts second makes one
  • Computers & Internet
