20 Most Recent
Pentax K20D 14 Megapixel SLR Digital Camera w/ 16-45mm lens, Shake Reduction, 2.7 High Resolution LC Questions & Answers
I have a Pentax K20d DLSR camera. I ordered a
If the lens has an "A" setting, be sure that's where you have it set. Clean the contacts on the lens and camera body where they meet with a cotton swab lightly dampened with rubbing alcohol.
Pentax K20D pink strip on photos
Go to the support section of the Pentax website and e-mail your question to their techs. I believe this is a known problem with a solution.
Iso stuck on 400
Go into the menu and scroll to "reset"...follow the on-screen instructions.
Why does it take so long to show to the photo after I press the shutter button?
The picture displays after the file has finished saving - if the speed of your SD card is slow, it can take quite a while before the picture is displayed. It also takes a while (up to a minute or more) if the shutter speed is low and the picture is mostly black (taking nighttime moon shots for instance).
Try using a better quality (higher speed) SD card.
Why isn't my K100D Flash not working?
please ensure that you've not used the camera for more than the advised amount of time by the manufacturer. Also, you can attempt to use the same brand/type of batteries as was including with your camera when you got it. Some manufacturers put internal fimware/software restrictions on their devices. For printers, this would be done for cartridges and in the case of your camera, it would be for batteries.
Lastly, I would check that your sd card isn't full before calling Pentax to refer you to a repair shop.
Thank you.
Pentax Espio 60S "E2" error
Hi for anyone reading this! My 60s was just flashing with this but I fixed it. Took the batteries out, swapped them and that didn't work. Tried to put the old ones back in a few minutes later and then it was fine! Just fiddle around with it. Hope this helps.
I need a driver update for my pentax optio rx18. can download one from your website
Hello, Susan -
Fixya.com does not have updated drivers for any computerized equipment. If you have not already done so, I suggest you contact Pentax directly regarding an updated driver for your Optio RX18.Pentax is owned by Richoh.You may be able to find assistance from another Optio RX18 owner through the
PentaxForums.com :https://www.pentaxforums.com/forums/7-pentax-compact-cameras/194995-pentax-optio-rx18-rz18.htmlYou will need to register (free) to post a question on a forums.Best wishes.
