20 Most Recent Digital Blue EasyShare MD1063 Digital Camera Questions & Answers
0answers
Kodak md1063 cant upload pictures
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
11/19/2014 5:26:52 PM • Digital Blue... • Answered on Nov 19, 2014
I have tried charging my camera and changing the
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/19/2010 2:36:31 AM • Digital Blue... • Answered on Sep 19, 2010
I have kodak md1063 memory card will not format
Hi there
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • 8/27/2010 7:56:51 PM • Digital Blue... • Answered on Aug 27, 2010
    Drop cameras sand on the beach it will not on.
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I brought my Kodak MD1063 to the beach and it didn't work for days, even after cleaning the battery connections and charging fully. I used the post below and it is all fixed! (Honestly, I think trying to turn it on and off a bunch helped clear the sand out of the lense which was causing the camera to shut back down.)
    Fixing a Lens Error on a Digital Camera
    This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
    The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
    A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
    Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
    The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
    Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
    Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
    Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
    Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
    Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
    Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
    Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
    Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
    8/4/2010 10:47:19 PM • Digital Blue... • Answered on Aug 04, 2010
    3answers
    Camera Kodak md1063.
    This problem is frequently due to weak/worn out batteries or corroded battery terminals inside the camera. Before you purchase new batteries, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
    http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
    It uses a simple Q&A format to diagnose problems and propose solutions.
    8/4/2010 10:44:20 PM • Digital Blue... • Answered on Aug 04, 2010
    2answers
    I try to turn my kodak camera on and it tries
    8/4/2010 10:39:25 PM • Digital Blue... • Answered on Aug 04, 2010
    I put my 1GB memory card into the camera and it didnt work
    iput 1gb card in cam i delete allpic?again i want takepic but not working
    4/11/2010 7:46:54 PM • Digital Blue... • Answered on Apr 11, 2010
    3answers
    My kodak md1063 digital camera switches on then
    My kodak Easyshare C653 camera is 2.5 years old when suddenly did this a few times then completely refused to turn on at all. Research showed me that this is a firmware issue in Kodak cameras. Kodak website said it will look at it and try to fix it for minimum $70 which is not worth it in my case as I paid $130 for the camera brand new 2.5 years ago. So either pay the $ for kodak to fix or buy a new camera is the solution. I am buying a new camera but it won't be a kodak this time as I want a camera that last years and won't go dead after warranty runs out.
    1/30/2010 6:46:24 PM • Digital Blue... • Answered on Jan 30, 2010
    Transfer problem with kodak MD1063
    With the cam connected , open the easyshare software ,bypass the transfer window then click on the ADD PICTURES icon on the top left,under SELECT A LOCATION click on the model no. of the cam. Tag all the pictures you would like to add, then click on ADD PICTURES. Click on DONE once finished.
    1/12/2010 1:54:58 PM • Digital Blue... • Answered on Jan 12, 2010
    2answers
    Not staying on
    its a common problem with the internal power supply you need to contact Kodak to see if theye will warranty the power supply and fix it for you
    10/24/2009 9:49:24 PM • Digital Blue... • Answered on Oct 24, 2009
    My battery compartment door is broken, can i order
    Unfortunantly KODAK doesn't sell spare parts.
    But you can order a small parts repair of 24,47 pounds,
    Contact KODAK:
    http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
    10/16/2009 7:05:27 AM • Digital Blue... • Answered on Oct 16, 2009
    My digital camera doesnn't turn on
    Here are the steps:
    1. Make sure you will install a new or fully charged battery/batteries into your camera.
    2. Clean the battery contacts.
    a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
    b. Reinstall the battery/batteries into your camera
    3. Without the memory card,turn on your camera.
    If issue persists, call 1.800.235.6325 for repair.
    Thanks.
    Neerak21
    9/28/2009 8:48:43 PM • Digital Blue... • Answered on Sep 28, 2009
    Kodak Easyshare camera model MD1063 wont turn on
    hi,your camera needs a servise , its a lance problem just open your camera and remove the lance assembly and servise it properly , otherewise contact authorised person,
    8/30/2009 4:05:00 PM • Digital Blue... • Answered on Aug 30, 2009
    Broken screen :(
    This is NOT a warranty claim. You broke it by misuse and therefore it will not be replaced under a warranty. Warranties deal with manufacturers faults. To repair this is expensive and I would suggest biting the bullet and buying a new one is cheaper and easier to do. In future carry your camera in a bag not your pocket as it will be too easily damaged
    7/22/2009 10:48:08 PM • Digital Blue... • Answered on Jul 22, 2009
    Camera/computer say memory card "needs to be formatted".....
    i would save your pictures on to a disc, then re-format the card.
    4/5/2009 2:32:06 AM • Digital Blue... • Answered on Apr 05, 2009
    When I turn the camera
    format the camera
    1/10/2009 8:04:13 PM • Digital Blue... • Answered on Jan 10, 2009
    2answers
    I forgot the combination to my safe can i reset it
    limited info generic answer notify manufacturer or locksmith for assistance
    4/16/2024 7:20:17 PM • Cameras • Answered 2 days ago
    Activition code digital tv 2050
    Free version does not require activation, but unsure if that will work for you. Web site specifically states there is not any activation code and not supported. All of its software is "free, freeware, shareware, full version, trial, demo or open-source" https://www.download.hr/software-digital-tv-2050.html
    4/15/2024 9:02:35 PM • Cameras • Answered 3 days ago
    Digital Blue EasyShare MD1063 Digital Camera Logo
    22 questions posted
    Top Digital Blue Cameras Experts
    ZJ Limited
    ZJ Limited
    ADMIN Andrew
    ADMIN Andrew
    Are you a Digital Blue Camera Expert? Answer questions, earn points and help others
    View Most Popular
    • Digital Blue Cameras
    Most Popular Question
    tried charging camera changing
    • Cameras
