20 Most Recent
XO Vision EM104VID MP3 Player Questions & Answers
Icant put videos on ematic mp3 player?
What you need to do is have your videos set to be converted by the MTV convertor that came with the device. It's usually on a mini disk.
You have to download the software and then input the video you want to convert.
The thing is that not any video will be recognized by the software. You'll need to convert most stuff to .avi files first.
For example, if you download a non-copy righted clip from youtube, you have to convert that to .flv format. (I recommend keepvid.com) Then you need to run that that to an .avi format. For that I would use MediaEncoder from sourceforge.
6/5/2019 7:39:44 PM •
XO Vision...
Answered
on Jun 05, 2019
Tengo un mp3 ematic seri
http://www.ematic.us/faq.phpThis model do not need a driver for connecting to windows xp ..it wil install auto ..as a removable storage device ..and you will find it in My computer folder ..Just drag the files into this folder ..(into the audio folder )
The firmware updates are also not available ..on the support site.....If you have trouble powering it up ...use the reset button ..located into the side or bottom hole ..(just press it with a sharp object ...when it is powered on ..and keep pressing until restarts..This will reset ti to factory settings ..)
Este modelo no es necesario un controlador para la conexi?n a windows xp...wil instalar auto...como un dispositivo de almacenamiento extra?ble...y encontrar? en la carpeta Mi PC...Simplemente arrastre los archivos en esta carpeta...(en la carpeta audio)
Las actualizaciones de firmware no est?n tambi?n disponibles...en el sitio de soporte.....Si tiene problemas para alimentar hasta.. .utilizar el bot?n Restablecer...situado en el lado o inferior agujero...(s?lo la prensa con un objeto afilado.. cuando est? encendido...y seguir presionando hasta que se reinicie...Esto restablecer? ti configuraciones de f?brica...)
8/17/2011 4:46:09 AM •
XO Vision...
Answered
on Aug 17, 2011
Can I use itunes on my ematic mp3??
iTunes is not in MP3 format so they will not play on an MP3 player. They use a modified ACC file extension that is only reconized by Apple products.
1/14/2011 1:06:06 AM •
XO Vision...
Answered
on Jan 14, 2011
I have a ematice mp3 player and i can't put any of
It works the same as an external memory device. When you plug the USB into the computer, it should show up as another drive. Open the drive, then drop files in the correct folder....MP3 files go in MUSIC, and AVI & WMV goes in VIDEO,etc...
The ematic comes with software to convert video into 320x240, and it comes out great.
Good Luck!
2/11/2010 5:49:11 PM •
XO Vision...
Answered
on Feb 11, 2010
GIFT CARD FROM ITUNES
you can't put itunes music on a mp3
if you really want music for your mp3
try P2P programs like limewire
6/17/2009 2:00:31 AM •
XO Vision...
Answered
on Jun 17, 2009
Mp3 player won't load properly
It sounds like your mp3 player has whats known in the tech world as a lot of bloatware or crapware, as we geeks call it. Its extra software that companies put into tech gizmo's to sell their software. I usually try to remove the bloatware by deleting it from my gaget.
