20 Most Recent
Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO) Questions & Answers
Activation key
http://www.truevision.com/PublicSite/us/Products/Consumer+Products/PCTV+Tuners/PCTV+Analog+PVR+(cable_antenna)/Pinnacle+MediaCenter+Support/Download+Area/Drivers+-+Updates/PCTV+Drivers.htm?mode=documents&newProductDisplayName=PCTV+110i&newProductName=PCTV+110i
copy and paste all of the above into address bar this site has updated drivers etc while there on the site go to products/TV viewing check more files or request help from them
Upgradation of driver
If the driver works in win xp there is no need to upgrade the driver.
On the other hand if you need the driver for xp it is here :
http://members.driverguide.com/driver/detail.php?driverid=84546
Drivver for GmbH (pro)
I HAVE NO DRIVER OF PINNACLE INTERNAL TVTUNER GMBH(PHILIPS SAA7134HL CHIP).PLEASE HELP ME TO ARRANGE THE DRIVER OF THIS TVTUNER FOR XP.THANKS
Hi..i have a pinnacle pctv
In windows 7 there is a program called windows xp mode, you can run prgrams that arn't supported by windows 7 in it. It can be downloaded free of charge off of microsoft's website. If that for some reason does not work, you can install virtualbox. Either way I don't think it would be possible for it to be used in win7 because of the incompatabilities. You can ring pinnacle and ask but I dont think they will be abkle to do it sorry. Hope it helps
Where can I get software an driver for Pinnacle
Thx but no thanks for the help; the specific question here was:
"Where can I get software an driver for Pinnacle PCTV Pro for windows 7"
In other words, if you had taken the time to do a quick google on this , you'd have found that this is an uprising issue, PINNACLE have no support for Pinnacle PCTV Drivers for in Seven as of yet.
Mind you , I think we're not all that stupid, if Karp1998 (goran) has posted his question here in a last desperate attempt, it's most likely that he's allready been around the web (including the official site : drivers support) before ending up here. By consequent I think personally your answer is a little light and breif. Things as a fact in this case seem obeous enough. So again thaks for the help, but no thanks... :) (No offense)
As for my part, I am also looking for those same drivers for my own PCTV and have come up with not much so far, keeping in mind I am in the computer technology industry, .... And I still ended up here like the rest looking for answers, that doesn't make me a dweeb , LOOOOL :)
-=[MAD-MAX]=-
I CANNOT TRANSFER VIDEO FROM
Well there is a problem in the driver of your camcorder, the driver does not support the operating system Vista 64 bit,
sorry to say that the driver for your camcorder Vista 64 bit not available on the Internet, you can contact to panasonic to get your driver or you can try connecting your camcorder to a Windows Xp operating system. please follow the below link to contact panasonic -
http://www.panasonic.net/contact/
Post comment if you need more help or information.......
Good Luck!!
Thanks
How to connect Pinnacle Video to HDTV?
You will need the correct cables to connect your card via your HDTV.
You really should download the manual for both TV and Card before attempting to make connections.
I bought my pc tower used from a co-worker, and he
The number that the install program needs is the software serial numberthat was on the jacket of the install disk. The drivers for the card should load without a serial number, but the main application needs it. Check with Pinnacle support, but I suspect you will need to purchase a new copy of the software.
