20 Most Recent Haier 7 cu. ft. / 198 liter Chest Freezer HCM070LA Questions & Answers
The starter is no longer available. I have found
I use this on a regular basis and have had no issues. I believe it will work. If I had some numbers from the compressor plus a brand name such as Copeland, Tecumsah, embraco, etc., I may be able to tell you more about the compressor HP.
8/11/2017 1:57:49 AM • Haier 7 cu. ft.... • Answered on Aug 11, 2017
Why My haier model hcm070la Chest freezer the compressor is not kick on
check thermostat, or relay on one side or back cclose to the compressor area there is a removable lid. removed and look for a thermostat disconect the 2 wires and bridge them then plug the the freezer on if runs replace the temp thermostat for a new one should be freezer thermostat
12/4/2016 12:26:34 AM • Haier 7 cu. ft.... • Answered on Dec 04, 2016
When cleaning my Haier 7 cu. ft. / 198 liter Chest Freezer HCM070LA we tipped to get water out and now it seems to not want to freeze but stays cold
Oil in the evaporator. It may come back if you leave it running for a few days, but usually needs flushing out.
5/3/2014 2:54:46 AM • Haier 7 cu. ft.... • Answered on May 03, 2014
After placing my Haier 7 cu. ft. / 198 liter Chest Freezer HCM070LA in a horizontal or tilted position it doesn't want to freeze
If you have run it in a tilted position, the oil has migrated from the compressor to the evaporator. You need a technician to flush the oil back to the compressor. Only run equipment like this on a flat level surface. and always allow to stand a few hours after moving before switching on.
5/3/2014 2:48:05 AM • Haier 7 cu. ft.... • Answered on May 03, 2014
How to put refrigerant into a gvt44AD
Hi, please help me, my freezer Gvt44ad when I conect to the power start to work for 45 seconds then it is off, can you give me some directions to do something for it?
10/17/2013 3:38:04 PM • Haier 7 cu. ft.... • Answered on Oct 17, 2013
2answers
I bought a used Haier
First, i will advice you check if the compressor and fan works when you plug the freezer, from your explanation, the click sound seems to me it could be a faulty compressor.
Before testing the compressor motor, unplug the freezer to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it may contain a lethal electrical charge. Do not touch the terminals until you have discharged the capacitor. The problem could also be a relay problem,. The function of the start relay is to momentarily energize the start winding in the compressor motor and then cut power to the start winding as soon as the motor is running. Most of the start relays on modern compressors are solid state and use a special material whose resistance increases with temperature. So, as current flows through the relay and the relay heats up, its resistance increases to the point that the start winding is isolated from the rest of the circuit.
A common failure of these relays is that the solid state material "cooks" and breaks up, staying open and thus never allowing the start winding in the compressor motor to energize. The end result is that the compressor tries to start, usually you'll hear a humming noise, and then, after a few seconds, the compressor's overload protector takes the compressor offline with a loud CLICK. Easy way to tell if the start relay is bad is by simply removing it from the compressor's control pod and shaking it. If you hear any rattling, it's fried.
6/6/2011 9:29:15 PM • Haier 7 cu. ft.... • Answered on Jun 06, 2011
Compressor runs but freezer not getting cold
Have the gas checked. If the thermostat pick-up is frozen over that could result in the contents of the freezer not getting cold, but for that there would have to be a build up of ice on the sides of the freezer.
1/25/2011 5:39:31 PM • Haier 7 cu. ft.... • Answered on Jan 25, 2011
My Haier 7cu. ft. deep freezer gets hot on the
It 's builded that way so there's not condensation around the door frame and on the walls.
11/4/2009 6:55:49 AM • Haier 7 cu. ft.... • Answered on Nov 04, 2009
Why does it get hot on the front and the sides it
If the food is at normal temperature, then what you are describing is normal.
On a chest freezer the condenser coils are embedded in the outer walls, as the evaporator coils are embedded in the inner walls to provide cooling.
This is the very basic principle of refrigeration. One set of coils (the condenser) are allowed to get hot, so the other set of coils
(the evaporator) can get cold.
When the unit is not running, which is most of the time, the walls will cool to room temperature.
11/3/2009 10:00:11 PM • Haier 7 cu. ft.... • Answered on Nov 03, 2009
Runs fine then for weeks then trips on high limit
Hi, sometimes high-limit goes bad, but why, check to make sure you're not overloaded with produce, check to make sure freezer has good ventilation, if your days are hot, high limit will switch off, to pretect compressor, could be compressor getting faulty, you should empty freezer, clean and restart empty for an hour, if freezing o/k, put back produce, if when clean and empty, does same thing, maybe your compressor is faulty, called a mechanic, or replace high limit switch. good luck.
8/10/2009 1:18:03 AM • Haier 7 cu. ft.... • Answered on Aug 10, 2009
2answers
Installation manual for walk in freezer
you search on net.
4/30/2021 2:53:27 PM • Haier Freezers • Answered on Apr 30, 2021
What does Ed mean on a haier freezer and how do I get rid of it
You can try resetting it by unplugging it for 10 minutes.
The Ed error code is referring to the defrost heating system.
10/28/2019 11:50:26 PM • Haier Freezers • Answered on Oct 28, 2019
How to stop the alarm going off on an upright Haier freezer.
https://www.haierappliances.com/support/freezers/troubleshooting try this web site for direct answers from the manufacturer.
5/29/2019 1:43:04 AM • Haier Freezers • Answered on May 29, 2019
Haier chest freezer doesn't cool, indicator lights don't come on, doesn't make noise when plugged in, could the indicator lights stop it from working?
If compressor isn’t running, it’s either a thermostat / control board problem, or a power supply problem.
1/30/2019 6:44:34 PM • Haier Freezers • Answered on Jan 30, 2019
My haier freezer will not start, power button is on but run button is not on
If compressor isn’t running, it’s probably a thermostat problem
10/11/2018 1:37:57 PM • Haier Freezers • Answered on Oct 11, 2018
How do I get manual for Haier freezer?
https://www.manualslib.com/brand/haier/freezer.html Identify the model and free manuals online at the link shown. Haier Freezer manuals
5/24/2018 9:57:05 PM • Haier Freezers • Answered on May 24, 2018
Haier 7 cu. ft. / 198 liter Chest Freezer HCM070LA Logo
Popular Tags
13 questions posted
Top Haier Freezers Experts
NOEL
NOEL
Rob Hill
Rob Hill
Are you a Haier Freezer Expert? Answer questions, earn points and help others
View Most Popular
Haier Freezers
  • Haier Freezers
Most Popular Question
bought used haier
  • Freezers
