20 Most Recent Haier HRF10 Top Freezer Refrigerator Questions & Answers
0answers
I have a 2010 chevy impala and there is a clicking sound that comes from my dash can you help me please?
A common cause is the heater blend door. This is a little door under the dash that determines how much warm air to mix with cold air from outside for your heater. Sometimes moving the temperature control to a different setting can reset a stuck door. There are hundreds of other possible causes, but this is where I would start.
4/24/2014 5:39:21 PM • Haier HRF10 Top... • Answered on Apr 24, 2014
My lawn tractor will not turn over i just get as clicking sound
Charge or replace battery
3/15/2014 9:55:40 PM • Haier HRF10 Top... • Answered on Mar 15, 2014
Would the defrost timer cause the fridge not to cool
In one post you saud the fans run but not the compressor. I believe that either the compressor sart relay, overload and run capacitor are the most likely problem causing the compressor to not run. You also could have a defective compressor so until you check the compressor I would wait before buying a lot of parts. Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
10/25/2012 5:04:17 PM • Haier HRF10 Top... • Answered on Oct 25, 2012
The freezer temperature is too high.
I've made a mistake before with thinking that I was setting the adjustment correctly on a refrigerator before, sometimes those dials are hard to read if there is a graphic scale, or symbols etc. Instead of numbers with the highest number being the coldest setting. Anyway make sure the temp setting is set correctly, these are found in the refrigerator side.(yes even for the freezer, so it does'nt freeze up) I adjust mine all of the time, things only need to be so cold right.(helps my elect bill) Make sure those special compartments have clear air passages to them. best regards.
2/9/2011 7:05:42 PM • Haier HRF10 Top... • Answered on Feb 09, 2011
My door won't stay shut. How can I adjust the door
First of all is this top freezer/refridgerator new or has the consumer had it for awhile? If not new, could have frozen food, piece of ice, etc obstructing the door. If you have frost(ice build-up) you could probably turn down the temp adjustment, might not need to be quite so cold, just a suggestion. Open the door and check the seal for damage, there is a magnetic strip in the seal that sticks to the body of the fridge keeping it shut along with vacuum etc. Check seal before calling service (800) # for further advice/ servicing. Good luck, best regards.
2/9/2011 6:37:28 PM • Haier HRF10 Top... • Answered on Feb 09, 2011
The freezer is cooling but the refrigerator
The defrost drain is blocked..This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle.Seems like it is blocked with water or ice.
Unplug the refrigerator, empty out the freezer compartment
pull off the back panel or the bottom panel (in the freezer compartment) Look for that defrost drain hole..
pour small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. Repeat this until I get the water to go down the drain tube..
hope this help......
7/28/2010 8:55:07 PM • Haier HRF10 Top... • Answered on Jul 28, 2010
2answers
Haier HRF10 what would happen to the fridge without condenser
it could but the possibility is low but you willl ruin the ref doing that
6/29/2009 11:11:56 PM • Haier HRF10 Top... • Answered on Jun 29, 2009
Haier HRF10 Moaning sound coming from Condenser fan.
It is the fan, Its time for a new one or try to oil her.
6/29/2009 3:05:57 AM • Haier HRF10 Top... • Answered on Jun 29, 2009
2answers
Haeir HRF10 refrigerator
Remove coil on back of refrigerator very gently and support the coil against a kitchen chair or counter. On the back of the refrigerator there is an access panel. Remove 4 screws holding the cover. Remove the bottom of the freezer compartment by removing screws and pulling bottom straight out. Remove Styrofoam panel from freezer by cutting tape along side edge. Once the Styrofoam panel is removed you will see fan blades. O n the front of the fan blade there is a spring. Pull the spring off by pulling straight forward with pliers or fingers. Remove the 3 screws holding the fan motor to the refrigerator in the rear access panel. The Motor should now be free. Unplug the plug from the connector by lock latch and pulling straight up. Now you must free the fan blade from the fan motor. Grasp the fan motor and pull straight out. This fan blade is really hard to get off. Try separating the two halves of the blade, where you removed the spring, with a screw driver. The motor is available from Repairclinic.com. Good luck.
1/8/2009 2:01:34 PM • Haier HRF10 Top... • Answered on Jan 08, 2009
0answers
Freezer is cold cold....fridge is at approx 50 degrees
Hello lmk400,
Welcome to fixya,
You siad, your freezer is cold cold....fridge is at approx 50 degrees What could it be ????????
1. The first thing it could be is that you have a freezer that is packet to the ceiling.
And so full that it's articles are covering the air vents found in the rear of the freezer.
They are need to be clear for the cold air to circulate form and to the fridge compartment.
Yes that is correct!
The freezer and the fridge both share the same air and to restrict the air causes the other
to get warm.
And will eventually burn out your fan motor or possibly your compressor!
OR
2. Your fan motor is already burned out.
Try checking this and clearing the vents.
It will take some hours to get cold and all night to reach peak temperature, if this is your reason!
If not you should then try turning off the fridge AND, then unplugging it for five minutes.
This should reset the system if there is an electronic glitch!
If all this fails you may be low on freon and need service to add some.
If the fridge was left open a crack all night or all day by accident it will cause this!
or if you go shopping and while unloading or loading the fridge with the door wide open running back and forth to the kitchen table for some extended time to!
Gather all the cold stuff near the fridge and put them in quickly!
I gave you a lot to work with and I hope the first two suggestions are the fix and solve your problem.
Let me know!!!!
Huuum
Please rememebr to leave me a rating at our fixya site!
10/21/2008 2:13:21 PM • Haier HRF10 Top... • Answered on Oct 21, 2008
Freezer cold, but Fridge only a little cool
Sounds like you have a defrost problem either the Timer /Heater or Bi-metal stat is bad. you can unthaw and the unit will work fine for about a week until it frosts up again Where was this screw they said was loose?? have them check the defrost system.
8/28/2008 1:21:03 PM • Haier HRF10 Top... • Answered on Aug 28, 2008
Haier HRF10 Top Freezer Refrigerator Logo
Popular Tags
32 questions posted
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Haier Refrigerators
  • Haier Refrigerators
Most Popular Question
freezer cooling but refrigerator
  • Refrigerators
