20 Most Recent
LucasArts Entertainment Company Star Wars The Force Unleashed Questions & Answers
No action figure
You are the action figure. Change to third party view to see the action figure.
1/18/2009 2:38:02 PM •
LucasArts...
Answered
on Jan 18, 2009
PS2 Star Wars Force Unleashed Game won't run
Another thing you might want to check is the system settings on the PS2. Start the PlayStation 2 console with no disk inserted in the drive. Upon loading to the main screen which states "Browser" and "System Configuration", press the X button on the controller. You will see five categories, highlight the PS Driver category, and then press the Triangle button once. Verify that both options within say "Standard". If they do not, then please use the steps below to change them.
- Use the D pad up and down to select the option that needs to be changed.
- Once the option is highlighted, press the X button once
- Use the up and down keys on the D pad to change the option to the Standard setting.
- Press the Circle button once to confirm the change
Next, use the D pad to select System Configuration, then press the X button. Using the up and down arrows on the D pad, cycle through the options on the screen and confirm that they read as follows.
Digital Output - Off
Component Out - RGB
Language - English
Screen - Full (This toggles the letterbox functions of the console, and may not be fully supported within the functionality of some games).
If any of the options are different from what is stated above, then, with the option highlighted, press the Triangle button. Use the D pad left and right to select the option that matches what is listed above. Once the correct setting is selected, press the Circle button. Once all the options are set as listed above, press the Circle button to return to the Main menu.
You may also want to try enabling the Auto-Diagnosis feature of the PS2, which will allow it to auto-detect the best settings to use when playing DVD's.
To Activate the Auto Diagnosis
- From the Browser and System Configuration menu.
- Press the triangle button to select Version.
- Highlight the Console from the list and press the triangle button - this accesses the next menu option.
- The Diagnosis will be highlighted.
- Press the X button to access the options available.
- Highlight "ON" and press the X button to affect the change
12/18/2008 1:52:43 AM •
LucasArts...
Answered
on Dec 18, 2008
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
When the game turns on
Pokemon crystal is a Game boy color game, there for it will not run the original Game boy.
What are some good catering services?
I recomenr you Alchemiq, it is a quality caterers https://alchemiq.com/catering-nyc/. They offer gourmet appetizers, fancy food stations, upscale cocktail catering, and event design
Recommended System Requirements
Find out if you can run that game on your PC Learn about. System Requirements Lab
www.systemrequirementslab.com
you can find here the minimum and required system requirements for most of the games and the updates needed for you to download to make the games run on your system.
Update profile
Clear your question, because which types of profile update. Then i better answer given.
Thanks.
Well i got the new
Unfortunately, your Logitech controller uses the DirectInput control standard, and Deathly Hollows Part 1 will only work with the new XInput standard introduced in Windows 7. The only Xinput controller so far is a 360 controller hooked into the PC. There are also some software emulation solutions, but those can be a bit tricky and buggy to use. For the best experience, I'd recommend purchasing a 360 pad and the corresponding wireless sensor.
