20 Most Recent
Nokia Lumia 820 Windows Phone Black Questions & Answers
Why can't I accessmy 500mb of data on my nokia windows phone?
Check the settings to ensure data is turned on. Check the data sense app to make sure you don't have a limit set. Check with your service provider to ensure no limits are set. Turn off WiFi. Try restarting the phone. Are you receiving any error messages?
Error code 0x0
write some email explaining the problem, in order to get help.God bless you
Att 820
Warning! By performing "Factory Reset" all user will be ERASED. You must backup First your Data.To Hard reset.1. On the Start screen, tap ->2 Tap Settins -> about phone.3. Tap reset your phone, and then tap Yes
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity.
Backup contacts from broken nokia 2730c-1
Yes, there is a solution to backup contacts from your broken Nokia 2730c-1.
Before flashing the phone, one option is to try using Nokia Suite software on your computer to connect to the phone and backup the contacts. Another option is to remove the SIM card from the phone and insert it into a different phone to access and backup the contacts. You can also try using third-party software or services that specialize in extracting data from broken phones. It's important to act quickly to ensure you don't lose any important numbers. Good luck!
