20 Most Recent HP ENVY 23-d065 TouchSmart All-in-One Desktop PC Questions & Answers
[email protected]
Do you have an error code or error message? Some e-mail servers won't allow certain file types such as vbs, mdb and similar extensions (dangerous attachments) or perhaps with large file size. Try compress your attachment (by zip or 7zip) and put some password on it.
7/29/2014 5:34:31 AM • HP ENVY 23-d065... • Answered on Jul 29, 2014
No power to hp envy
Hi, I suggest you step by step follow check it your Desktop issue. A> All power plug proper connect or not, if possible change another port. B> Have your ups get power or not, If ups on then nest step follow. C> Check it SMPS on or off position. If your power ok and come to smps or smps not start then you SMPS damage position, you check it smps ok conduction or not.. Checking method: SMPS more wire available you see it one more bulk wire available and black wire and green wire cross check, if not start smps then damge. But my friend if you smps ok or your are wrong wire attach then may be your smps damage. So better contact good Computer Hardware Technician. Thanks. Computer Support
2/20/2014 7:35:25 PM • HP ENVY 23-d065... • Answered on Feb 20, 2014
0answers
0answers
0answers
Stuck cd
Be the first to answer 1/31/2014 3:16:14 AM • HP ENVY 23-d065... • Posted on Jan 31, 2014Be the first to answer
2answers
Error code 80080005
Is your windows updates disabled? Is your anti virus up to date? Do you have a Malware program, updated? If you do not have MALWAREBYTES download and install :http://www.filehippo.com/download_malwarebytes_anti_malware/ Run a FULL SCAN, may take hours, depends on HDD size. Delete ALL RESULTS. I don't know your OS? Vista? win7? 32? 64? Her is a standalone windows update for both 32/64:
http://download.windowsupdate.com/v7/windowsupdate/redist/standalone/WindowsUpdateAgent30-x86.exe or
http://download.windowsupdate.com/v7/windowsupdate/redist/standalone/WindowsUpdateAgent30-x64.exe
12/29/2018 3:29:51 PM • HP TouchSmart... • Answered on Dec 29, 2018
2answers
HP IQ772 power but no boot
all PC's fail. (Virus is #1 ) what OS (xp,vista, w7) ? is this PC in UK, England? HP shows, CIRCA 2007 build, (1st) and is near out of support) sure... you skipped the first steps. 1: battery out, get it out of the pc. 2: use only he a.c line pack , 3 it has PSU are all power pins reading correct voltage? must 4: if above ok, the BIOS works, on all systems, GET BIOS to work first. do you know your BIOS hot keys, its very important to learn this first if working on any PC made ever. 1981 to now. see this yet, the BOOKS http://support.hp.com/us-en/product/HP%20TouchSmart%20IQ700%20Desktop%20PC%20series/3351217/model/3561184/manuals?jumpid=reg_r1002_usen_s-001_title_r0001 best is not to pull any Cmos battery , just use a volt meter there, 3v is good, 2v bad. see? or scramble all BIOS setting including boot drive... arg. this box has no standard VGA 15pin jack on rear, making tests with external display hard use a flashlight pointed at screen see any data if yes the blacklight in the LCD is dead. (BIOS screens dead) does boot up, F11 bring up windoz recoverY. odd machine, wireless mouse and keyboard the latter begs the question gee how can we get to BIOS lacking a keyboard, driver in BIOS ROM. curious ,,, on line i see no body getting BIOS screens. fresh battery in keyboard, what happens here. If the hard drive errors happen before you can get to a recovery screen, try this:
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F8 key repeatedly as the computer starts. An "Advanced Boot Options" screen opens.
  3. Select Repair Your Computer and press Enter .
  4. Select a keyboard layout that matches your country/region and click Next .
  5. When the login prompt appears, select the user name with Administrator rights (not Administrator) from the User Name drop down. The user name with Admistrator rights is most likely the first user name that was entered during the initial computer setup.
  6. Type the logon password into the Password field (press Enter if you didn't put in a password) and then click OK . A System Recovery Options window opens.
  7. Click Command Prompt .
  8. At the prompt enter: c:
  9. At the c prompt, enter: chkdsk /b
  10. If a message opens saying you need to forcibly dismount the drive say yes.
  11. When it is done, try to do an F11 recovery again.
black screen has many causes. if its not just the back light dead, use a flash light first get BIOS to work, do you get F8 or F11 screens this is key to solving the true cause on all PCs. one can use a USB keyboard if yous dies. ask here , on the real forum. http://h30434.www3.hp.com/t5/Desktop-Video-Display-and-Touch/IQ772-Boot-Up-Problems/td-p/64527 i read your 2 users guides, no one word on BIOS that is BS. and due to now rear VGA port (has some mini bs jack) you cant see if the PC is dead or just the silly display or GPU chip dead., a preplexing box, i never buy those i get real DT or top HP laptops. all in one boxes are custom, and tricky to fix. for sure the nasty VGA trick missing, JACK
9/22/2017 1:08:34 PM • HP TouchSmart... • Answered on Sep 22, 2017
Welcome screen for windowr10 not accepting password
It seems that installation didn't go very well. I have done many upgrades and it picked user name and password. No problems. Try to get a disk with the version of windows 10 you downloaded so that you revert back to the previous version or do a repair. Since I am not in front of your computer and as a technician then i could find some other information.
10/12/2015 2:50:56 PM • HP TouchSmart... • Answered on Oct 12, 2015
When I turn on the pc it goes to a blank white screen how can I fix this
CHECK THE VGA-CABLE. TRY WITH A OTHER MONITOR.
4/19/2015 11:03:35 AM • HP TouchSmart... • Answered on Apr 19, 2015
2answers
Why does my computer fan suddenly run faster
As the cpu (central prossing unit also known as processor) heats up the fan will surge to cool it down. Nothing to worry about. If this helps you rate favorable.
2/24/2015 5:34:49 AM • HP TouchSmart... • Answered on Feb 24, 2015
How to make my crystal 660 printer compatible with HP touchscreen?
Drivers are created by the manufacturer. This is made by the Swedish manufacturer, Sagemcom. When I looked up the specs on the printer, I discovered that the manufacturer is Sagemcom. http://support.sagemcom.com/site/se/philips-fax-11/philips-crystal-660-337 Note that the top of the page tells you to go to a link for a critical update for the Crystal products. It will prompt you for numbers pertinent to your printer. When you look at the bottom of that page, you discover the printer is XP SP2 compatible. There is no mention of it being Windows 7 or Windows 8 compatible. Windows 7 driver.If you have Windows 7 Professional, Ultimate or Enterprise, you may be able to install your printer using Windows XP Mode. You will have no luck searching for support on a Philips page but may through Sagemcom as advised above.
2/20/2015 5:25:10 AM • HP TouchSmart... • Answered on Feb 20, 2015
Windows 8 logs me out after playing a video (YouTube/CNN/yahoo) if I let it finish playing I get logged out
Matthew, It sounds like your computer thinks it is inactive. To fix this, visit this website to correct your automatic log off settings. Lock Screen Timeout Period Change in Windows 8 These images will also help point you in the right direction. 25299915-q0gunzvds02ql12gf1i0eigt-4-0.jpg Take care and have a great day! -Alex K. 25299915-q0gunzvds02ql12gf1i0eigt-4-2.jpg
11/29/2014 8:36:25 AM • HP TouchSmart... • Answered on Nov 29, 2014
Keyboard typing automatically
This can be a few things. 1. Stuck keys, some keyboard can get dust, food, hair in them which cause the keys to stick. If you have a vacuum cleaner you can gently vacuum the keyboard to remove some of these obstructions. 2. bad keyboard, if after cleaning the keyboard the problem continues you may have a bad keyboard and it may need replaced. If it is a desktop you can pick them up pretty cheap at almost any store that sells computer parts. If it is a laptop the keyboard can be replaced as well, but may need to be done by a computer repair shop or other professional. 3. virus, back in the 80s-90s viruses that allowed another person to take control over your computer where very common. Now days these types of viruses still exist but are not as common. You may need to update and run an anti-virus program or have your computer looked at by a computer repair shop. However, I would not do this until the first two solutions have been tried. Further help can be provided if you let us know if full sentences are being typed, or just random letters.
11/11/2014 5:22:14 PM • HP TouchSmart... • Answered on Nov 11, 2014
Touchsmart 310 pc
You'll want to first make sure your computer is off and unplugged from power. Here's a generic tutorial on how to remove a CPU heatsink. This may vary slightly from your computer, but should be similar enough to get you pointed in the right direction: removing stock AMD heatsink and thermal compound AM3 cpu
9/2/2014 7:11:02 PM • HP TouchSmart... • Answered on Sep 02, 2014
I can get into yahoo but can not get into my email, something about certificat problem. What should I do?
Check that the time, date, and timezone are correct on your computer. The problem you describe can be caused by these being incorrect. Additionally, you may want to update your web browser(s) to the most current versions.
9/2/2014 4:45:48 PM • HP TouchSmart... • Answered on Sep 02, 2014
How to unistalled it home page reset
Tools, options
8/26/2014 2:33:09 PM • HP TouchSmart... • Answered on Aug 26, 2014
Light static noise coming from HP Envy desktop periodically but consistant
Try to double check on where the noise is coming from for us to be able to start isolating the problem
8/6/2014 12:47:35 PM • HP TouchSmart... • Answered on Aug 06, 2014
HP ENVY 23-d065 TouchSmart All-in-One Desktop PC Logo
8 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
TouchSmart HP
  • TouchSmart HP
Most Popular Question
windows media player not responding
  • Computers & Internet
