20 Most Recent
Megatronix - TW71 - 5 Button 2 Way LCD Motorcycle Transmitter Remote Replac Questions & Answers
Autopage xt74 alarm in silent mode
The only reason that your alarm would not chirp when locking and unlocking the doors is that the system is in valet. A visual notification that the alarm is in valet mode is the LED light is on solid. If the LED is on solid and you wish to make the alarm active again, turn the ignition on then, press and hold the valet/programming switch for two seconds. The LED light will turn off.If the LED light is not on solid then, the issue may be with siren itself.
Need to program autopage 5b remote
Note: This mode will only retain the last 4 remote transmitters programmed. If the transmitter memory is exceeded,
the security system will start deleting transmitters from memory in chronological order.
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in ON position. Within 15 seconds.
2. Push the Valet switch 3 times and holding in on 3rd push until a long chirp is heard then release the valet switch.
You are now in the Transmitter programming mode.
3. Press and hold any button of the transmitter until the siren responds with a confirming chirp, indicating the signal
has been stored into memory.
4. If you have additional transmitters (up to 4) that need to be programmed, repeat step 3 for each transmitter.
Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. 3 long chirps & 3 parking
light flashes will confirm exit.
Remote says OUT OF RANGE when i try to arm it.
Reprogram the remotes using this procedure:
REMOTE TRANSMITTER PROGRAMMING
Enter:
2. Push the Valet switch 2 times and hold in on the 2nd
push, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:
1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
Lights dont flash when arming and disarming system
If the lights on your system are not flashing when arming and disarming, there could be a few reasons for this issue. Here are some potential causes and solutions:
- System Configuration:
- Check https://mmfinancials.pk/gold-prices-in-pakistan-experience-a-dip-in-line-with-global-trends/ the system configuration settings. Some security systems allow users to customize the behavior of lights during arming and disarming. Ensure that the settings are configured to activate the lights as desired.
- Power Supply:
- Verify that the system has a stable power supply. If the power is insufficient or there's an issue with the power source, it may affect the functionality of the lights. Check for any loose connections or power interruptions.
- Light Bulbs:
- Inspect the light bulbs associated with the arming and disarming indicators. If the bulbs are burnt out or faulty, they may need replacement. It's a simple fix, but it can have a significant impact on the visibility of the system's status.
- Sensor Issues:
- Some systems use sensors to detect arming and disarming actions. If these sensors are malfunctioning, they may not trigger the lights properly. Ensure that the sensors are clean, properly aligned, and functioning correctly.
- System Software Update:
- Check if there are any software updates available for your security system. Sometimes, manufacturers release updates to address bugs or improve functionality. Updating the system software may resolve the issue.
- Faulty Wiring:
- Examine the wiring connecting the lights to the security system. Loose or damaged wiring can disrupt the communication between the system and the lights. If you find any issues
My auto page alarm wont
I have 09 envoy 4x4 with auto page remote with electric start but it stopped unlocking my doors ? It worked and now nothing just locks and start work any fix to this issue ?
Xt 65 h50t31
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
Try it out brother
