20 Most Recent
Hobart 24 in. LXIC-5 Built-in Dishwasher Questions & Answers
Detergent error
I'm a hobart tech---been away for awhile.What is the model lxih,lx30?Let me know if you still have a problem with it.
Ecomax 500-10
Hello. Have you find a wiring diagram for Ecomax 500-10 dishwasher ?
I constantly get the "E4" error every time I turn
1. Low water pressure - check for clogged hose strainer; ensure
the site water pressure meets minimum flow pressures.
2. Make sure probes are clean. (See Cleaning.)
3. No water pressure - main water supply valves may not be
working.
4. Anti-siphon valve - located in the lower left area of the chamber
just above the water line. Drain the machine and insert a toothpick
or similar object into the hole to verify ball (" OD) is free to float.5. Delime machine.
Not reaching temp
On the machine that we have, there are two [2]push button switches in line for the heater tank. One is on the front of the tank and the other is around the right side. I have always called them clicks-on's but.. they are red in color and need to be rested if ever they get to hot. Be sure to relise that they did infact pop for some resone. Did the tank for some resone run dry?
Hobart battery charger
model # 750H3-18 hobart charger gets a abonormal shut down light after overnight charge on different machines.
What is error code 10?
you may be able to find out the code number by going to the manufactures web site enter your model number , and any other information it asks for . you might need to call fro service
Taking to long to wash
How long is it taking?
Does it stay in the wash cycle or advance into the drain cycle?
Does it flash the word "fill"?
Do you get an icon of a wrench with a number or letter?
What is the flow pressure when it fills? should be 20 psi +-5.
What type of detergent is used for a lx30c hobart undercounter dishwasher
What type of detergent is not necessarily important - anything intented for use in commercial dishwashers should be sufficient. A restaurant supply store should have something suitable for you.Also, in case you don't already know, the LX30C is the non-booster-heater version of the LX30 (LX30H has a booster heater). Without a booster heater, you'll need to use chemical sanitizer. The LX30C should, hopefully, have a sanitizer pump installed to inject chemical sanitizer into the rinsewater stream. Most of these dishwashers also have a detergent pump to inject detergent into the wash tank and rinse aid pump for chemical rinse aid.If present, these pumps are located in the bottom of the machine. Remove the lower front panel (2 screws) and look for the small, black plastic assemblies with 2 hoses connected to each.
