20 Most Recent Samsung Galaxy Note 2 N7100 24Gb White WiFi Android 3G Cell Phone Questions & Answers
2answers
I need unlock my cell phone
NOT NOTE
6/7/2013 11:49:42 AM • Samsung Galaxy... • Answered on Jun 07, 2013
2answers
Samsung manual for 2.1 soundbar subwoofer m AH68-02078F
How i connect to my tv
4/16/2024 1:24:29 AM • Samsung Cameras • Answered on Apr 16, 2024
Samsung ES80 Digital Camera. It is not charging and the red light is not flashing.
The battery has probably failed due to lack of use and regular charging Remove the battery and check it with a multimeter. To see the camera on your laptop you would normally need the software and drivers for it. Support link https://www.google.com/search?q=samsung+es80+software+download Battery https://www.google.com/search?q=samsung+es80+battery ..
2/18/2024 8:00:02 PM • Samsung Cameras • Answered on Feb 18, 2024
My Samsung Es90 digital camera's shutter is not working, plus, the batteries are fully charged but when inserted, it only last 2-3 minutes. What can I do to resolve this?
I'm assuming by "shutter" you're referring to the one inside the camera and not the cover blades on the very front of the lens. How old is the battery and do you use the camera a lot? Old batteries can be fully charged but can become weak and not hold that charge when the camera is powered on. The shutter issue could be part of this as the battery might not be strong enough to power the shutter. I think the batteries for these cameras are reasonably cheap so you could invest in a new one to see if that helps. An extra battery is always useful if you use the camera a lot. If this is an old, well used camera part do wear out so if new battery doesn't help you may need to take it to a good repairer as the camera will need to be taken apart to find the problem.
1/19/2024 10:45:50 AM • Samsung Cameras • Answered on Jan 19, 2024
How to record using SAMSUNG DIGITAL CAMERA DV150F.
How to record Video? check out the manual
SMART CAMERA DV150F ' Samsung Support CA
Samsung https://www.samsung.com > ... > Camera > Compact SMART CAMERA DV150F. Solutions & Tips, Download Manual, Contact Us. Samsung Support CA. ..
11/14/2023 6:33:29 PM • Samsung Cameras • Answered on Nov 14, 2023
Samsung vp-d361, can't detach the battery.
The battery has probably swollen, they do when left flat for a long period of time. Brute force is all you can use and hope you don't destroy the fixings.
10/21/2023 12:20:12 PM • Samsung Cameras • Answered on Oct 21, 2023
Samsung Digimax 301 will not turn on only green light flashes
  1. Check battery polarity: Ensure that you have inserted the AA batteries correctly, aligning the positive (+) and negative (-) ends as indicated by the camera's battery compartment. Improper battery placement can prevent the camera from powering on.
  2. Clean battery contacts: Over time, battery contacts can accumulate dirt or corrosion, hindering proper electrical connections. Use a clean, dry cloth or a cotton swab dipped in rubbing alcohol to gently clean the battery contacts inside the camera's battery compartment. Make sure to let the contacts dry before reinserting the batteries.
  3. Replace batteries: Even though you inserted fresh AA batteries, it's possible that they may not have sufficient power to operate the camera. Try using a different set of new batteries or fully charged rechargeable batteries to eliminate the possibility of a power issue.
  4. Reset camera settings: Some cameras have a reset option that restores the default settings, which can help resolve certain issues. Look for a small reset button or a menu option within the camera's settings to perform a reset. Refer to the camera's user manual for specific instructions on how to reset your Samsung Digimax 301 model.
  5. Firmware update: If your camera has an outdated firmware version, it may cause compatibility issues or malfunctions. Check the Samsung website or contact their support to see if there are any firmware updates available for your camera model. Follow the provided instructions to update the firmware if necessary.
6/3/2023 12:48:29 PM • Samsung Cameras • Answered on Jun 03, 2023
Samsung NV3 Camera. No file, what do I do?
This is a very cryptic, non specific, vague question. Google seems to think that you are trying to say in the least amount of words that there are no files on your SD Card?? https://www.google.com/search?q=Samsung+NV3+camera+no+file This usually happens if you are using a modern SD Card that is FAR too big for the camera specs, OR you didn't format the card within the camera. The Maximum capacity you can use is 2GB Your Samsung NV3 Digital Camera is compatible with 2GB Micro SD memory cards. Maximum Memory Capacity: 2GB Cable Type Compatibility: USB Memory Card Compatibility: Micro SD https://www.google.com/search?q=Samsung+NV3+camera+no+file ..
4/12/2023 3:03:53 AM • Samsung Cameras • Answered on Apr 12, 2023
2answers
Samsung SL202 card error I bought an SD card with adapter and camera says "card error".
Question edited for clarity.This is always because people buy modern SD Cards that are far too bit for older cameras. The maximum size for an SD Card is 2GB. Also you must format the card inside the camera.https://www.manualslib.com/manual/145868/Samsung-Sl202.html?page=86&term=SD+card&selected=1#manual..
3/20/2023 10:11:34 PM • Samsung Cameras • Answered on Mar 20, 2023
How do I download the pictures off the Samsung AF zoom 1050 to my computer?
Is this a 'wind up'? This is an old style film camera. You put film in and send it to be developed! Here is the manual https://www.cameramanuals.org/samsung/samsung_af_zoom_1050.pdf ..
3/10/2023 6:41:52 AM • Samsung Cameras • Answered on Mar 10, 2023
I have a compact Samsung camera WB350F. When I switch it on it says it is connecting to the computer although it hasn't been asked to do so and it sticks in this mode until I remove the battery.
There are a few possible reasons why your camera is behaving in this way. One possibility is that the camera's firmware is malfunctioning, which can cause it to get stuck in a loop trying to connect to a computer. Another possibility is that the camera's USB cable or port is damaged, which can also cause this issue. If the problem persists, it would be best to contact Samsung customer service for further assistance. They will be able to diagnose the issue and provide you with a solution.
1/18/2023 10:48:42 AM • Samsung Cameras • Answered on Jan 18, 2023
My Samsung ES25 won't turn on, I tried replacing the batteries with new 2450 MAH batts. But it wont turn on, what should I do?
Maybe this will help; https://www.youtube.com/watch?v=yw3HuN-KGCg
9/29/2022 7:28:07 AM • Samsung Cameras • Answered on Sep 29, 2022
How can I download Samsung camera PL100 software on SD
Hi, Please visit the Samsung website and search for your device's page. There should be a download section there that you can use. Thank you.
9/26/2022 8:31:53 PM • Samsung Cameras • Answered on Sep 26, 2022
Why is my pl90 samsung digital camera saying that i have the memory card in erong when its in right
Try this. First try another memory card. This will help work out if it is a camera or a memory card issue. Remove the card and take a very close look at the metal contacts on it. Your looking for dirt or damage like scratches or missing metal.
Next using a light, look inside the slot the card fits into for loose dirt or lint.
Connect the memory card to your computer/laptop and check the card registers on there. You could also try re-formatting the card to clear it and reset it to factory level.
9/14/2022 11:30:21 AM • Samsung Cameras • Answered on Sep 14, 2022
Can't find my software for digimax 240 where can I get?
will my digimax 240 work with my laptop windows8 WHAT STOPPED YOU FROM TRYING the Pc must be internet connect for w8 PnP plug and play to work the CAM< came new with the SOFTWARE driver, on CD lost the CD but wait it only does windows XP max. on disk the only manuals and drivers are here at the makers web site UK (guessed) https://www.samsung.com/uk/support/model/EC-D240ZSBA/E1/ 2008 time stamped proves Vista max if at all. USB driver. the manual too is there. this cam first sold is 2002 20 years ago., pause for effect.
7/19/2022 1:37:46 PM • Samsung Cameras • Answered on Jul 19, 2022
Have a Samsung Galaxy tab pro 8.4 , replaced battery and charging port and won't charge
This could be a lot of things, first is check the charger with a volt meter to be sure that it is suppplying the right voltage. The next thing is to disassemble it and check parts that you probably dont have the right gear for and if you do get the gear you are going to spend more than it is worth. There are MOSFET devices inside and they are mounted on the surface of the board, they require special tools etc. Here is a guy that does a lot of these to show what is involved. NorthridgeFix - YouTube
7/8/2022 10:41:30 PM • Samsung Cameras • Answered on Jul 08, 2022
Samsung Galaxy Note 2 N7100 24Gb White WiFi Android 3G Cell Phone Logo
3 questions posted
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cameras
  • Samsung Cameras
Most Popular Question
39 m looking unlock code samsung n7100
  • Cameras
