20 Most Recent
Kenmore Slider/Casement Air Conditioner Questions & Answers
Icing of cooling coil
Cehck you filter make certain it is clean .. its normal to see ice on the coils esp during real warm humid days .. I don't think you have much to worry about .. let me know if it gets sorse though > Hope this helps .. Jon
7/24/2011 7:11:23 PM •
Kenmore...
Answered
on Jul 24, 2011
Kenmore electric range gets a f1/f3 error code
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
9/18/2010 9:13:24 PM •
Kenmore...
Answered
on Sep 18, 2010
I bought a casement kenmore
most likley the compressor capacitor .unplug the unit remove the knobs by pulling them off..take screws out to open cover behind switches ..inspect wires first look for burnt or broken connections if all looks good /look for the capacitor it is silver /round or oval shape .look to see if the top of capacitor is bulging or leaking acid/this part helps the compressor start replace with new ..let me know ..good luck/joe/
8/26/2010 10:16:16 PM •
Kenmore...
Answered
on Aug 26, 2010
I have a Kenmore Air Conditioner Model No.
Make sure the filter and coil behind the filter are not dirty (I am sure you did that already) as this would cause icing and excess water build up. There may be a steel or plastic plug in the bottom rear of the unit. If not, I have drilled a hole in the very rear right or left side of some to help drain the water, but you need to be sure that nothing, nothing at all is on the otherside where you drill (No wires, no tubing, no compressor, etc,) as you will damage the unit. If it is a newer unit under warranty call the manufacturer as newer units disipate the water in the exhaust air and it may be malfunctioning or it may just be extremely humid ouside and the unit is struggling to disipate the water.
8/7/2010 4:37:59 AM •
Kenmore...
Answered
on Aug 07, 2010
My air conditoner was purchased brand new in 9/09
Since it worked when you first got it and it's brand new - I would check the electrical breaker that it's on.
Sometimes a breaker will trip for no reason.
An easy way to do this is to plug something else, i.e. a hair dryer into the outlet that the AC is plugged into.
If the hair dryer does not work you know your problem is with the breaker.
If it (hair dryer) does work - then it's a problem with the AC which would surprise me - since it's a new one, and it worked before.
Good Luck!
5/7/2010 5:52:34 PM •
Kenmore...
Answered
on May 07, 2010
My kenmore 12k BTU window unit will not turn on
Hi, check house panel circuit breakers or fuses, check receptacle/outlet. if you got plug/receptacle, check for reset button, press reset. if there's power at receptacle, could be faulty circuit board. good luck
9/10/2009 9:00:05 PM •
Kenmore...
Answered
on Sep 10, 2009
I have a kenmore casement model number
you have to remove the unit from the window and unscrew the cover which will allow you to clean the inside of the evap and condenser coil and oil the fan motor if it has oilers the easy way to clean it is to take it to a self use car wash. do not use the strong spray as it can bend the fins.
7/8/2009 10:06:39 PM •
Kenmore...
Answered
on Jul 08, 2009
