20 Most Recent Kenmore 146010 Humidifier Questions & Answers
Can't find valve button for float (part #28110101 no longer available)
Greetings!
We just got a new furnace with humidifier, so they took out our old Kenmore humidifier.
We now have 4 of these parts...........valve button for float #28110101.
Linda
3/20/2021 1:16:22 AM • Kenmore 146010... • Answered on Mar 20, 2021
0answers
Can't find float valve button for kenmore humidifier
Searsparts.com
3/7/2010 4:16:04 AM • Kenmore 146010... • Answered on Mar 07, 2010
Trying to find owners manual for Kenmore Humidifier 14114 please?
Question edited to clarity. The first link should be close enough? https://www.google.com/search?q=kenmore+humidifier+14114+manual ..
11/20/2022 1:14:57 AM • Kenmore... • Answered on Nov 20, 2022
Kenmore humidifier it keeps showing EE IN CONTROL PANEL
Thank you for your question. I can understand your concern about this error code. This code indicates the sensor has failed. However, if the touch pad is not responding it can also be causing this code to appear. If the touch pad does respond properly, the sensor # 610.14 will need to be replaced. The sensor is available at searspartsdirect.com/partsdirect/part-number/610.14/0046/461?pathTaken=directMatch&filterPart=&pop=flush&prst=0&shdPart=610.14&sid=MMLxexpertxmerch and sells for $2.16. You can call 1-800-469-4663 and someone there may be able to assist you with the cost of the service call and the technician will be able to give you an estimate for the repair. I hope this will help you. If you would like more assistance, reply to this thread and I will be glad to assist you further
4/10/2019 9:49:27 PM • Kenmore... • Answered on Apr 10, 2019
I have a problem with a Kenmore Dehumidifier not working. It's a Kenmore model 251.50701011. When I first started having trouble with it - the compressor wouldn't turn off.
Likely the evaporator froze as a result of low refrigerant pressure. IOW it needs a shot of freon, so to speak. (probably doesn't use freon)
2/1/2019 1:23:42 AM • Kenmore... • Answered on Feb 01, 2019
What are the ages of my Kenmore model #758.144170 and model #758.144533 humidifiers?
Both 10 years, the third digit of the Model of Kenmore represent the year manufactured they also apply it to their other products.
10/3/2018 4:16:55 AM • Kenmore... • Answered on Oct 03, 2018
Kenmore 756.15412 humidifier CK FILTER indicator stuck on.
Look for other areas where the airflow may be blocked.
11/6/2017 1:23:16 AM • Kenmore... • Answered on Nov 06, 2017
0answers
My Kenmore Humidifier 15420 has a code of "cf" what does it mean?
Depending on your model, the CF could mean the filter needs to be changed or that the unit needs to be reset. If your model doesn't have a reset button, you can unplug the unit from the outlet for 5 minutes.
1/18/2017 11:40:19 PM • Kenmore... • Answered on Jan 18, 2017
Kenmore 146010 Humidifier Logo
Popular Tags
5 questions posted
Top Kenmore Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Kenmore Humidifier Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Humidifiers
  • Kenmore Humidifiers
Most Popular Question
find valve button float part 28110101
  • Humidifiers
