20 Most Recent Barrecrafters /sportrack, Sx-12 Ski/snowboard Rack Questions & Answers
Need instructions for Barrecrafters ski rack
We figured this one out today, after pounding, twisting, sliding, gerunding, etc.
It will not slide backward (as a safety mechanism, of course) unless your latches (the ones that connect / clamp onto the car) are completely loose. That means, that looking at the rack from the end, you'll see this oblong deal that you'll use to tighten the rack to a car. As you turn it clockwise the rack will tighten, right?
Ok. Just make sure that that guy is as loose as he gets, and your piece will slide back just fine.
4/4/2021 9:10:27 PM • Barrecrafters... • Answered on Apr 04, 2021
I have a Barrecrafters Sierra
Hello there, getting replacement keys for your ski rack is possible. Usually to get replacement keys all you have to do is visit your local distributor. Apparently the keys can be re-ordered from the manufacturers although the name of the manufacturers have been changed to proline products. here is the web address http://www.prolineracks.com maybe an order can be placed from there. Or you could get more information from calling their customer service and locating the nearest distributor to your location.
Hope this support has been helpful?
Thank you for visiting FixYa.
8/8/2011 1:11:40 AM • Barrecrafters... • Answered on Aug 08, 2011
Bought a barrecrafter car rack
look and see if there are any letters and numbers scribed on the face of the lock cylinder, this is the key code-- with this code you should be able to go to your local locksmith and they will be able to cut you a ' key by code ' and it will work. if there is no code on the lock then you can also just take the rack to the lockshop and they will be able to pick and remove the cylinder from the lock and fit a key to it by hand. normal shop rates for making a key in this fasion is about $12-$15 dollars and if you want more than one key - duplicate keys cost about $1.75 to $ 2.50.
(( even if the lock does have numbers on it -- take the rack to the shop with you to make sure the key that they cut by code works before you leave the shop,,, saving you a second trip ))
c...
1/11/2011 12:11:04 AM • Barrecrafters... • Answered on Jan 11, 2011
I need a replacement key
Need the manufacture to help you more or you can go to a Locksmith to make you a new one between 10-15 dollars. Or you can read the 4 diget code where you put the key in and call you local locksmith to see if they can cut you a key. Good Luck
7/31/2010 7:06:12 PM • Barrecrafters... • Answered on Jul 31, 2010
I have lost the key to my Barrecrafter ski rack
Find a dealer in your area, it should have a number on it for them to get you a replacement. OR, most locksmiths should be able to do the job while you wait.
2/6/2010 12:07:31 AM • Barrecrafters... • Answered on Feb 06, 2010
I need to know were to buy an additional fastners
Try the local snowboarding shops, or online directly thru Barrecrafter. Also a local Hardware store my have stapping that may help you out. good luck enjoy the snow
12/7/2009 1:42:28 PM • Barrecrafters... • Answered on Dec 07, 2009
I have a 2006 Polaris 900rmk snowmobile it keeps overfueling at idle I believe it is one of the injectors on pto side not sure which one of the 2 affects your idle any ideas?
they both can repair manual show how to trouble shoot --------https://snowparts.ru/manuals/Polaris%20Trail%20600-900%20RMK%20Switchback%20Service_Manual_2005.pdf
1/10/2023 1:06:51 PM • Winter Sports • Answered on Jan 10, 2023
No spark on 02 ski doo legend
You have a bad coil or wire.
1/3/2023 2:25:15 AM • Winter Sports • Answered on Jan 03, 2023
2answers
Spark plug gap on a 2006 Polaris 700 Classic
It depends on the brand of spark plug you are using. https://www.google.com/search?q=2006+Polaris+700+Classic+spark+plug+gap ..
12/18/2022 3:53:35 PM • Winter Sports • Answered on Dec 18, 2022
2answers
Wearfit 2.0. Why can't I bind to my iPhone?
Discord users facing issues like How To Fix Discord Not Opening so just make a call on Discord Customer Support 1-802-618-6092 anytime and experts are there on Discord Live Chat to help you 24*7 . Need any kind of guidance to fix the Discord issue so just make a call on Discord customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7
2/24/2022 9:59:23 AM • Winter Sports • Answered on Feb 24, 2022
2003 Ski-Doo Grand Touring 550 Fan. All of a sudden I have no spark! What could be the problem?
kill switch --ign switch--cdi--magneto--broken wire --etc https://ski-doo-snowmobile.brssm.com/ https://www.snowmobilerepairmanual.com/ski-doo-repair-manual/
1/16/2022 5:08:05 PM • Winter Sports • Answered on Jan 16, 2022
Skandic Skidoo. How do I take out a battery that is located underneath the seat of a Skandic Skidoo
Question edited for clarity. Question moved from Seat Cars (Spanish car maker and pronounced See-at) to Snowmobiles Category. The are videos and text based articles. The best bet is to fit pigtails to the battery and had a plug for a battery maintainer. You never have to remove the battery, and you never have to worry about it it not being charged. https://www.google.com/search?q=skandic+skidoo+remove+battery ..
1/15/2022 10:33:14 PM • Winter Sports • Answered on Jan 15, 2022
2012 Switchback adventure 600
MAYBE IT NEEDS SOME OIL ADDED
1/4/2022 7:51:27 PM • Winter Sports • Answered on Jan 04, 2022
3answers
What types of waxes are used in cross-country skiing?
There are four different types of waxes that are used: waxtapes, glide waxes, klisters, and kick waxes.
6/25/2021 3:58:02 PM • Winter Sports • Answered on Jun 25, 2021
1991 Polaris Indy 500 Classic. How do you remove the chain case? It seems to be holding on the top?
I fixed the question and put you in the Snowmobile category Video instructions here https://www.google.com/search?q=1991+classic+500+replace+chain ..
6/4/2021 3:46:08 PM • Winter Sports • Answered on Jun 04, 2021
2007 Arctic Cat F1000. Why does it keep stalling while being ridden?
It could be many different items, choke stuck, ignition switch etc. but more importantly have you taken care of your recall? https://www.cpsc.gov/Recalls/2017/Arctic-Cat-Recalls-Snowmobiles
4/29/2021 5:05:37 PM • Winter Sports • Answered on Apr 29, 2021
Ski Doo. Where can I get a repair manual?
Try contacting Ski Doo directly to inquire.
1/23/2021 8:50:35 PM • Winter Sports • Answered on Jan 23, 2021
1996 Yamaha Vmax XT 600 snowmobile. How can I replace speedometer cable?
Unscrew it from the back of the speedometer and follow it back to where the cable terminates at the hub of the track. Undo it there and replace it with the new one. https://www.google.com/search?q=1996+Yamaha+Vmax+XT+600+snowmobile.+How+can+I+replace+speedometer+cable ..
1/19/2021 6:18:29 PM • Winter Sports • Answered on Jan 19, 2021
When do questions usually get answered?
6 months to a year after they are posted. not always but a lot lately !!
12/6/2020 4:58:52 PM • Winter Sports • Answered on Dec 06, 2020
Barrecrafters /sportrack, Sx-12 Ski/snowboard Rack Logo
24 questions posted
Top Barrecrafters Winter Sports Experts
Arnie Burke
Arnie Burke
john h
ADMIN Andrew
ADMIN Andrew
Are you a Barrecrafters Winter Sport Expert? Answer questions, earn points and help others
View Most Popular
  • Barrecrafters Winter Sports
Most Popular Question
barrecrafters sierra
  • Winter Sports
