20 Most Recent
Kenmore 8.8 cu. ft. / 249 liter Chest Freezer 13911 Questions & Answers
How tofind out if your chest freezer is stuck onn defrost mode
If its in defrost mode it will get warm and the frost will melt. People usually just unplug them. Tge compressor usually has a switch or temp knob. It may be in back by the compressor underneaith. There would be an indicator as to the temp.setting on it. It may not have one at all and may have another issue.
Freezer got unplugged, meat spoiled, freezer
I have found that the best cleaners for removing left over odors are citrus based cleaners. They help to neutralize odors and prevent re-occurrence. You could also use a diluted bleach as well to sanitize the inside. Make sure it is not too potent or the bleach odor will overcome the bad odor in annoyance.
Good luck!!
I have a freezer chest the compressor comes on but
. Cut everything off for a few minutes then turn it back on
and listen for a click from the compressor relay as the compressor tries to
start.
Is the compressor motor running.If no check starter/overload
relay.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Wont freeze
When changing the battery it should be a alakline. Also try unplugging the unit and then back in again. Check to see if the sides are getting warm which will indicate the compressor is running. Make sure the compressor is running. Check to see if thermostat is up high enough. The unit may have an electronic board that may be the problem. And lastly, it could have a sealed system problem, like a freon leak. You didn't say how old the unit is.
Chest freezer
Make sure you have power going to the unit. Check the thermostat for power on both sides going in and coming out. You need to give me more info. before I can suggest anything else.
Error code b on kenmore chest freezer
LOW / NO BATTERY ALARM
The Low/No battery alarm will activate when the
power level of the battery becomes low. The display
will alternate between "b" (Battery, See figure 8) and
the cabinet temperature, the red alarm light will
become illuminated and the control panel will beep
every five seconds. To stop the audible alarm (beep),
press the "ALARM RESET" button. The red alarm
light will remain on and the display will continue to
flash until a new battery is installed. This same alarm
will activate if there is no battery installed
