20 Most Recent
Kenmore 30 in. 32384 / 32385 / 32389 Gas Cooktop Questions & Answers
Control panel
Probably couple of hundred dollars installed. Might be time to replace stove!!
Gas stove digital clock
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
I have a kenmore gas range and on the display is
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
If I get the model # I can help you pind the right parts.
Good Luck and please rate 4 thumbs for the free answer
My oven want light its gas and the the pilot light islit
Is this a standard gas cook-top there maybe some small particle blocking the area where the gas comes out and lighting with the pilot. If you feel comfortable try lighting it with a match. First make sure there is not a lot of gas build open, so if there is a window near the stove open that and make you have plenty of ventilation before striking said match.
Safely remove knobs from 50's Kenmore gas stove
The safest thing to do would be to turn off the power ( un-plug it or turn off the breaker) or the gas or both to the unit. Turning off the power would probably be easier. There should be a gas shut off valve behind it.
New cooktop-1 burner does not light automatic
find the spark module. Follow the spark wires to the module . unplug the one that doesn't work and plug in a working wire. If it sparks it the wire if it doesn't spark change module
