20 Most Recent
Kenmore 36 in. 33384 / 33385 / 33389 Gas Cooktop Questions & Answers
Hey there,
Come on my dear it cannot just be a switch harness you need to check the whole cooktop if there is water still some where hidden inside it can develop into serious short circuit...It is quite very dangerous for you. so take it apart and check out cfompletely. If possible have a service call...
One burner won't ignite. The electode was
Most likely its dirty meaning the burners themselves and aren't getting any gas through. If you feel lucky you can do this without turning off or unplugging the stove, but on the oft chance there is a short I would do those just to be on the safe side. If you know how lift the top part of the stove up, you did not give model number. Find the electrode and clean with a clean toothbrush, plug in see if there is a sparks, actually look for the spark first. If you have a spark then your issue is the feed to your burners or the burners themselves being clogged. The feed is like a straw should there be an obstruction than nothing passes through. Clean the burners with a pin, blow through the gas inlets that go to the burners. After cleaning retry.
Ignitor
i may be late but did the cooktop get wet?
Why are all of my ignoiters are clicking in the off position?
Spark module is bad or a switch is stuck closed. You can check this by removing a wire from each switch to see if it stops. Need to take c/t apart. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Igniters will not work
did the water fall on the spark module do you hear a faint click ,igniters dont go bad if they get wet if you say theres power going to the cooktop then you might have a bad spark module.
Gas Cooktop
It is probably just a dirty orifice. It should be in the center of the burner and have a small hole in the top of it. Use something small like a paper clip or safety pin and poke in that hole a few times to clean it out. Let me know if this helps.
