20 Most Recent Electric Bicycle Motor, Bike,electric Bicycles ,kits Questions & Answers
IGo Core-Edge Electric Bike. Trouble shooting on igo e bikes core edge?
Question edited for clarity and correct order of 'make model (what it is)'. Question moved from Motorcycles category to e-bikes. In the link https://www.google.com/search?q=igo+core+edge+troubleshooting+guide ..
4/9/2024 6:57:24 PM • Electric Bicycle... • Answered on Apr 09, 2024
Wuxing eBike taking the throttle off?
Question edited into written English with punctuation and stuff. Question moved from Cars and Trucks See the 4th Image. Undo the grub screw and slide it off https://www.aliexpress.com/i/32908930427.html More here https://www.google.com/search?q=Wuxing+eBike+remove+throttle+off ..,,
10/26/2023 3:43:04 AM • Electric Bicycle... • Answered on Oct 26, 2023
Battery won't charge past 12.6 on my Fatman 1000
not car, is electric EV motory cycle or EV moped (it has pedals) batteries are charged and then load tested with a tool called the same powered by 1000-watt motor powered by a 48-volt 17AH Samsung battery. SAMSUNG Lithium Ion 48v not 12v. so bad charger, wrong battery put there or battery is bad we cant see what IS there blind so learn to test the battery first they fail at 1000 cycles, (short lived they are) you year told or how old battery is. any shop can test the battery and charger that came with the bike. let them?
12/21/2022 3:15:54 PM • Electric Bicycle... • Answered on Dec 21, 2022
2answers
Electric bicycle
Contact the seller for a manual http://www.omegastores.com/cozybikele.htm First remove the battery then find someway to support the bike as removing the rear wheel also removes the stand... Remove the 2 Philips head screws securing the rear mudguard and the 2 on the LHS rear axle cable protection cover & slide the cover off. Disconnect the rear brake. undo the rear axle nuts. Loosen the chain adjusters and slip the chain off. You may also have to deflate the tyre to get it past the mudguard.
4/9/2022 9:35:34 AM • Electric Bicycle... • Answered on Apr 09, 2022
3answers
I have a GIANT LA FREE SPORT ELECTRIC BIKE. THE
The brake handles have each have a switch button that must be pressed for the motor to work. (Actually what happens is that when you pull the break lever it unpresses the button so the motor won't work against the brakes). Just tape the switch down for the time being. Electric Bikes Northwest and David Hawkins might be able to help you with bike parts. I've gotten some parts from him for my La Free Sport. Very few bike shops know anything about these bikes. Good Luck! Dennis
10/4/2019 7:55:33 PM • Electric Bicycle... • Answered on Oct 04, 2019
I have a Velec 36. After turned off the headlight ,although turned off ,fades to s glow,but isn't fully out. Any ideas why?
The on/off switch mat not be completely opening the circuit. There is a high resistance circuit between the battery and the light even though the switch is in the off position. Check this with a multimeter on the resistance (ohms) scale. If the switch checks out ok, you will have to find the fault somewhere else in the circuit. Measure the resistance in sections of the circuit until you find the fault, then fix it.
7/11/2019 10:06:57 PM • Electric Bicycle... • Answered on Jul 11, 2019
Volt electric bike display unit..early model instructions
Try contacting this major Volt dealer for assistance: http://www.voltbikes.co.uk/contact-volt.php I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
8/25/2017 11:02:47 AM • Electric Bicycle... • Answered on Aug 25, 2017
3answers
Electric bike cuts out while riding
Couple possibilites. If it is just a matter of your battery clips coming undone, tighten the with pair of pliers then reattach. If it cuts out, then reengages when you start pedaling, either your controler is shot, or you have a ground short on your wheel hub. How long does a charge hold, and how often does it cut out?
7/13/2017 8:41:56 PM • Electric Bicycle... • Answered on Jul 13, 2017
2answers
Need to purchase charger - G4m20211-2347-E-16.
the price is $22 as a standard level 4 original batteries but beware of duplicates
6/15/2017 11:58:23 AM • Electric Bicycle... • Answered on Jun 15, 2017
Scooter won't go! no power from throttle
check for broken earth wire between hub and plug.i had same problem,i found a second plug half way along loom inside a piece of innertube sealed at ends with plastic tyes, 2ml black wire good luck.
4/19/2017 7:36:14 AM • Electric Bicycle... • Answered on Apr 19, 2017
I need the catalog or instructions for EV Warrior
try to search for it on the web i'm sure it will be of some help 2 u please vote 4 me
10/15/2016 5:58:23 PM • Electric Bicycle... • Answered on Oct 15, 2016
3answers
I disconnected my back wheel from the controller and now the motor doesnt work
You disconnected while under power didnt you? if so the controller output transistor(s) have failed. most likely the cause why it doesn't work anyway.
10/5/2016 1:54:39 AM • Electric Bicycle... • Answered on Oct 05, 2016
My cyclamatic bike hasnt been used for a while i charged the battery and it has a full charge but when i hit the on switch no power showing on the lights any ideas?
If the battery has charged and you confirmed this by testing the voltage, then it could be that the battery and/or switch has dirty contacts. Try cleaning the contacts or removing/refitting the battery a few times and turning the switch on/off a few times.
10/5/2016 1:28:36 AM • Electric Bicycle... • Answered on Oct 05, 2016
How do I diagnose my aprillia city enjoy that the motor doesn't work anymore
You can download the workshop manual from a few websites, including this one APRILIA Enjoy City Workshop Manual I would start by checking and cleaning the battery contacts where they connect the battery to the frame wiring harness near the seat post. The controller requires both 24V and 12V to activate the motor. If the battery gauge is indicating a full battery then it may be that the controller is not getting the 12V feed. I had to replace the controller in my Aprilia because it had a fault. There is a lot of information on the Aprilia Enjoy models here. Endless sphere com
10/5/2016 1:27:25 AM • Electric Bicycle... • Answered on Oct 05, 2016
Controllers instructions
Go to their web site
9/20/2014 10:24:17 PM • Electric Bicycle... • Answered on Sep 20, 2014
How can i install a headlight kill/pass light switch on hero Honda hf deluxe bike
First, on the positive side connect one side of a switch, then connect the other side to the cut wire.
9/20/2014 9:54:14 PM • Electric Bicycle... • Answered on Sep 20, 2014
Sekura electric bike I have power to lights and indicators but the bike wont drive.?
I am not familiar with Sakura, but if it is fitted with e-brakes then you could try disconnecting one then the other to see if it now works. If it does then your ebrake is faulty & you need to replace the brake sensor in the e-brake or the complete e-brake lever.
5/30/2014 2:56:26 AM • Electric Bicycle... • Answered on May 30, 2014
Electric Bicycle Motor, Bike,electric Bicycles ,kits Logo
132 questions posted
Top Electric Cycling Experts
john h
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you an Electric Cycling Expert? Answer questions, earn points and help others
View Most Popular
Electric Cycling
  • Electric Cycling
Most Popular Question
cyclamatic bike hasnt used while charged
  • Cycling
