20 Most Recent
Sony VAIO VGN-CS115J/P Notebook Questions & Answers
Horizontal lines sony laptop
Hook a spare monitor to the video output usually on the back of the laptop, if picture okay! the LCD panel on the laptop is faulty and must be replaced. If both show the same system it is the Video Graphic Card that is defective and usually built into the motherboard.
3/27/2012 9:01:21 PM •
Sony VAIO...
Answered
on Mar 27, 2012
Im having Sony Vaio VGN
this is a heat problem. try blowing the fan vent and all opening with air. a air compressor does this well. if you don't have one you can buy dust remove in a can.(same thing but compressed air in a can) they also sell a fan plate you can put under the laptop at walmart. (around 15 dollars) i use one on my laptop. i used Velcro to keep together. the fan plate uses a usb port to power it on. hope this helps and please rate. thank you.
1/8/2011 4:09:33 AM •
Sony VAIO...
Answered
on Jan 08, 2011
I have a VGN-CS115J for just about over a year
If you say that fans gives out loud swirling sound, i can suggest you update your bios because it is the one responsible for minimizing the noiseand making the fans swirl.
Possible that system is shutting down because fans might be shutting down as well.
You can also try to blow out some air on the vents because that is usually where your fans are, this will help clean out fans.
Questions: Does your computer restarts when it shutsdown automatically? if it is there might be a bluescreen error going on and bluescreen can either be a problem with software or hardware. A lot of troubleshooting needs to be done to isolate. Do the first solution that i have given you then answer my questions for further troubleshooting
6/4/2010 2:44:23 AM •
Sony VAIO...
Answered
on Jun 04, 2010
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
Lost video on svt131a11l
Try to:Open Computer by clicking the Start button and then clicking Computer.Navigate to the folder or drive that used to contain the video file, right click it and then click Restore previous versions. https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
9/30/2018 12:52:58 AM •
Sony VAIO...
Answered
on Sep 30, 2018
System has slowed down and freezes regularly. it
A lot of anti viruses cant find or get rid of pups, which are potentially unwanted programs that sneak onto your computer, go to mybleepingcomputer.com and download and run adwcleaner, its free and gets the boogy men out.
1/22/2018 2:02:26 AM •
Sony VAIO...
Answered
on Jan 22, 2018
