20 Most Recent Kenmore 53202 / 53204 / 53209 Side by Side Refrigerator Questions & Answers
Probably a heater element blown out. You will know for sure if she starts to frost up.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Kenmore 53202 /... | Answered on Dec 18, 2008
Tener, sounds like you have a module going bad. Pull off the white cover of the ice maker and take a look at the center white gear. There should be two clips securing the gear on. A lot of times these clips break and cause the gear not to rotate properly. Part number for the module is 628399. Take a look at this first. Catriver..post back
Kenmore 53202 /... | Answered on Nov 02, 2006
This can be a complex problem. Test whether the defrost heater circuit is getting 120 v from the main control board. If it is getting the voltage, the main control board is okay. You could have a broken heating element or a blown fuse in the defrost control assembly. Here's a video for a different error code that shows how to access the freezer evaporator in that type of refrigerator: youtube.com/watch?v=a4MdwuoN3jc Unplug the refrigerator and use the procedure in that video to remove the evaporator cover in the freezer. Check the resistance through the defrost heater and replace it if it's electrical open (measures infinite resistance). If the defrost heater is okay, you may need to replace the defrost control assembly which contains the defrost thermistor and fuse. You might want to call a service person on this.
Kenmore... | Answered 16 hours ago
u more than likely have to remove the bottom plate first and the screws along the back wall are most likely covered with a plastic covering
Kenmore... | Answered on Jan 14, 2020
There should be an access panel on the back side of the refrig. Remove that you you should see a tube running down into the drain pan. Often that tube gets plugged and needs to be removed and cleaned. If it is a rubber tube, consider replacing it as the rubber gets old and sticky with age and that stickyness causes the plugging.
Kenmore... | Answered on Jan 11, 2020
possible bad temp sensor or control board
Kenmore... | Answered on Dec 24, 2019
Something may be prevent it from installing correctly, subjecting it to undue stress leading to premature failure.
Kenmore... | Answered on Dec 16, 2019
Would you tell me why you want to repair this water line? I'm not clear about the problem you are having. To prepare the refrigerator for service. You will need locate the shut off valve to the refrigerators water supply line. After the water is turned off. You can slowly and carefully pull the appliance away from the wall. If the water supply line to the refrigerator is copper tubing. You want to move the unit as little as possible. The more it is moved the more there is a chance of developing a leak. Depending on the installer, they may have used copper or nylon tubing. Copper is similar to metal in the respect that if the line is bent repeatedly. The material will weaken and could crack. This will not happen quickly. It's just a good practice to leave it alone and move it only when necessary. Please write back and explain where the unit is leaking and let me know if you are referring to the water supply line going to the refrigerator. If you suspect that the water line inside the door is leaking please tell me where. It is a common mistake that owners think their refrigerator has a damaged hose. In actuality the water control valve assembly is worn out and leaking. Feel free to write back with any questions and I'll do my best to help you figure this out. You don't want to waste your time pulling a door apart when the problem wasn't even there to begin with.
Kenmore... | Answered on Dec 14, 2019
Kenmore 53202 / 53204 / 53209 Side by Side Refrigerator Logo
6 questions posted
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
icemaker slow make ice
  • Refrigerators
